Newbie here.
I have a TV where the sound works but the picture does not turn on. I opened up the back to see if I had any bad caps, but they all looked good to me. However, there was one wire that had obviously overheated and burned. In fact, it got so hot that it was burning the metal inside the TV! (see pictures)
So, I believe I need to replace this wire, but I have no idea where to start. The actual plastic wire to wire connectors appear to be fine -- it is the wire itself that is now exposed and has burned through itself.
Is there somewhere where I can buy a replacement part? Or do I need to buy the wire myself, and then somehow attach it to the wire to wire connector?
Here are my TV specs:
It is a Calypso (was a Staples in-store band), but I believe it uses Samsung parts. The model number inside the TV is T400xw01 v.6.
The wire to wire connectors are 13.00mm in size (these are the actual connectors: http://www.tkp.com.tw/en/product/13.00mm/TKP-0882.html)
One of the wires has printed on it: E215834 AWM STYLE 3239 22AWG 3KV-DC 150C VW-1 CSA TYPE TV-3 SILICONE RUBBER 150C NIZING
The other wire his printed on it: AWM3239 22AWG 200C 3KV VW-1 SILICONE RUBBER AWM 1 A/B 200C EKV PT1 SHENZHEN MYSUN (this is the wire that has burned through itself)
Please see attached pictures. Let me know if I can clarify anything.
Thank you in advance for any help!
PICS: http://imgur.com/a/gpG5X
Newbie here.
