Samson live l612 schematic, please help
  • brightm
    • Apr 2013
    • 11
    • cape verde
    Guys please if any one can offer me the diagram of this amplifier i will appreciate a lot, it cos i have one that was brought to my office and the sound transistor and ic were burnt that i cant see there numbers to replace them.
  • notallbad
    • Oct 2012
    • 1190
    Re: Samson live l612 schematic, please help
    Open it up and post board part numbers and photos too if you can.
    You might also be better posting this under 'Audio Equipment Discussion'
    • brightm
      • Apr 2013
      • 11
      • cape verde
      This is the photos of the board the place i circled with the red line is the places of the ic and transistors
      • notallbad
        • Oct 2012
        • 1190
        Does the board have a part number?
        Pictures are not very good, need clearer and closer images.
        • brightm
          • Apr 2013
          • 11
          • cape verde
          i have look through the board and there is no part number on it the only number i can see is something like u2
          • dicky96
            Does anyone have a schematic for Samson TXM16 Powered Mixer?
            by dicky96
            Hi guys
            Does anyone have a schematic for this? The fault is both protect lights on. I fixed one problem already that was causing the negative rail to both amplifier channels to go to -90V with +45V on the positive rail (It's a class G design)
            I now have 45V on both rails +/- but one of the amplifier channels has about 20V DC on all the emitter resistors and it all reads weird because the base of the NPN output transistors is about 8V so they are reverse biased, yet the base of the PNP output transistors reads about 19.3V, so 0.7V less than the emitters so those appear be forward...
            11-21-2022, 11:43 AM
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • atunguyd
            Acer x163w Monitor PSU schematic
            by atunguyd
            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
            03-05-2025, 02:08 PM
          • Thetechdude
            MSI Ventus RTX 4080 16G Broadview schematic needed
            by Thetechdude
            Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
            I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
            Thanks.
            07-15-2025, 11:15 AM
          • ianpoultonknights
            Zenbook Flip 15 UX562AI schematic
            by ianpoultonknights
            Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
            06-26-2025, 02:41 PM
