Panasonic P50S30 14blinks
+ More Options
Posts
  • don_mayor
    • Oct 2013
    fellas, i need your help. i have a panasonic P50S30, it went dead last year and started blinking 7x. Panasonic had a technician come change the SC, SU and SD boards, it worked. 6 months later, it went dead again, blinking 7x and this time. i'm out of warranty.
    i bought an SC board online and replaced the the burnt out one. TV went from 7blinks to solid red and still no picture. when i hold the power botton for more than 5 seconds. it starts to blink 14x.
    i've changed the P-Board, A Boards and still no picture, still solid red and 14x blinks.
    I need help or i'm gonna have to part the TV out.
    thanks
    Re: Panasonic P50S30 14blinks
    It's usually advised to swap the SU and SD at same time as SC replacement.
    • don_mayor
      • Oct 2013
      yeah i knew, but i examined the SD & SU boards and they're both brand new with no burnt marks.
        The buffers on these can fail without obvious burn marks.
        • riparo
          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
          by riparo
          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
          I attach a link to download the service manual, thank you for anyone who can help me
          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
          01-11-2024, 12:35 PM
        • CoinCoin88
          Panasonic PF50G20S blinking 13 times
          by CoinCoin88
          Hello there,
          Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
          Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
          06-30-2023, 05:43 AM
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
          11-20-2024, 08:52 PM
        • ItepK
          Panasonic TX-P42G30E green light blinking, no video, no audio
          by ItepK
          Hey everyone!
          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
          This post describes my entire troubleshooting process of this TV.
          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
          I've taken the unit apart, and I've started to check some voltages:
          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
          12-22-2023, 05:06 AM
        • Tof
          Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
          by Tof
          Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
          When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
          The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
          I opened it and found a burned connector on PB-board on the 24V pins.
          The 24V wires have change a bit of color due to the overheat and the corresponding...
          02-01-2022, 03:18 PM
