LG 47LM4600-UC 47 inch LCD TV With Sam Young Caps in Power Supply
  • leaver
    • May 2013
    • 17
    This TV would not come out of standby. I replaced shorted diode D607 on the power supply board and the set worked fine for a few days then quit again with the D607 shorted again. All the caps on were Sam Young and they looked fine to the eye. But I decided to replace them all since that brand is on the "Bad Caps" list. That did the trick and the set has been working fine for several weeks.
  • japlytic
    • Oct 2005
    • 2086
    Re: LG 47LM4600-UC 47 inch LCD TV With Sam Young Caps in Power Supply
    Good repair job.
    Electrolytic capacitors can fail without any external signs.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      I just fixed one of these. Had standby light and 164v across main cap. I tested diode D607 and it read short in circuit. Pulled a leg up and it was good. 1 inch away from it I saw the remains of a small blue cap. There was another one very close by, a 101k.
      I pulled one off a junk board and transplanted it. A working tv!
      • RDC55
        • Dec 2017
        • 180
        First of all thanks to the guys that posted about this issue with this TV, it really simplified determining what the problem is. And just to add some failure background, I was watching this when a fairly loud pop occurred and the TV went black with no sound.
        That said, I am hoping for some help identifying the value of the capacitor. It does not have any numbers on it and I have been unsuccessful in locating a parts list for the Lg 47LM4600. The part can be seen in first photo (C603) and has a black burnt mark in the middle of it. D607 read shorted as previously mentioned but OK when one lead lifted.
        Thanks in advance for any input
        • diif
          • Feb 2014
          • 6978
          • England
          C603 is a 220pF 1KV you can upgrade it to a 2KV.
          • RDC55
            • Dec 2017
            • 180
            Thanks diif - parts ordered and received from Digi-Key. I took your advice and upgraded to the 2 KV capacitor. I also went ahead and replaced D607 (MUR460) since it displayed some blackening on the one lead - it was likely fine but too cheap to take the risk. I will run it for a while and no news is good news.
            Just to add C610 main cap 160V standby and 395 operating.
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
