SANYO LCD-32XR12F; standby blinks 5 times and then all dead
  • inflex
    • Aug 2012
    • 545
    Picked up from a person, was hoping for the simpler leaky-cap failure after they described how it was difficult to get to turn on until it just stopped turning on.
    On powering up, the standby light blinks 5 times, then it's all dark.
    Testing the 12V and 5V lines on the logic board show that the PSU seems to be doing fine.
    The side power/menu/etc buttons generate appropriate voltage levels ( resistor divider ) but no response by pressing any of them.
    Remote control doesn't seem to invoke any responses either.
    Can't find a service/schem manual anywhere, might just end up binning it.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • inflex
    • Aug 2012
    • 545
    Re: SANYO LCD-32XR12F; standby blinks 5 times and then all dead
    Managed to find a sufficiently similar schem ( Sanyo 32" ), showing 5V-standby at 5.128V, so that's acceptable.
    Pressing the power-on button pulls the line down to GND but no power on results.
    What I cannot find in any of the service manuals though is the meaning of the 5 blinks on power up.
    • inflex
      • Aug 2012
      • 545
      Previous owner states that the unit became progressively less responsive to user inputs [ from remote? ] over time until such that it now doesn't start.
      Pondering if perhaps the main CPU needs reflowing :\
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • mecha1166
        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
        by mecha1166
        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
        07-01-2024, 05:47 PM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
