Philips 19PFL5522D/05 LCD TV with CapXon KF series capacitors on Delta power board
  • Arstar
    • Sep 2013
    • 4
    • United Kingdom
    The television picture suffers from colour and definition deterioration (dithering effect) after about a minute of being turned on. With a green tinge to everything, especially noticeable on blacks.
    I found three CapXon capacitors on the Delta branded power circuit board with slightly bulging vents. Position 1 had a small yellow crusty deposit at the vent apex that fell off when touched, and position 2 left hand has a small black deposit underneath the vent casing apex slit.
    Before I spend money on ordering replacement capacitors I wanted to check if they are the likely cause for picture deterioration? Or if problem is attributed to something more serious.
    Details for three CapXon KF range capacitors.
    16mm tall by 10mm wide. 5mm spacing.
    1 - 1000uF 10V KF105ºC P723 VENT
    2 - 1000uF 16V KF105ºC P727 VENT
    CapXon 6 page PDF file with specification.
    I was going to order from CPC as they have free postage, but open to recommendations for other UK suppliers if they carry more suitable stock.
    Planned replacement parts (differing series):
    1 - Panasonic FC series 1000uF 10V 16x10mm EEUFC1A102
    2 - Panasonic FK series 1000uF 16V 16x10mm EEUFK1C102
    Now I'm not sure if preferable to use the same series for all positions in picture, but CPC only carry the Pansonic FC series in the matching dimensions for 10V. If it is advisable to use to the same series/model line in all the positions I will look elsewhere.
    Which would be considered the best series/model line to use if I could find a complete set at another supplier?
    Thanks in advance.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Philips 19PFL5522D/05 LCD TV with CapXon KF series capacitors on Delta power boar
    I think it would fix the problem. And Panasonic FC is a great choice to replace CapXon KF. Replace them all though, not just the visibly bad ones. CapXon is an extremely unreliable company, and they will likely all fail eventually. Especially in a warm TV
    • Arstar
      • Sep 2013
      • 4
      • United Kingdom
      Going to have to use a different retailer and pay postage. One upside is a larger inventory choice. So now considering Panasonic FR range if that would be a better series to use?
      Panasonic FC PDF
      Panasonic FR PDF
      The FR range has about half the impedance value, and a higher ripple value (not sure if lower or higher number preferable). Also get increased life expectancy.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        FR would work. The ESR is pretty low but I think it will be fine
        • Arstar
          • Sep 2013
          • 4
          • United Kingdom
          Got around to replacing the bulging capacitors. Also replaced the two normal looking 1000uF 10V.
          Unfortunately it hasn't made a different to the picture so I'm cutting my losses.
          Won't be winning any soldering contest on my first attempt.
          Top row is three Panasonic FC series 1000uF 10V EEUFC1A102 10x16mm (width, height)
          Bottom row is two Panasonic FC series 1000uF 16V EEUFC1C102S 10x20mm
          1000uF 10V
          1000uF 16V
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
            ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 03:28 PM
            ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
