SCEPTRE x425bv-fhd NO video Powers Up
  • whatusername
    • Dec 2013
    • 456
    Re: SCEPTRE x425bv-fhd NO video Powers Up
    ok will do... I will post the results
    • whatusername
      • Dec 2013
      • 456
      Originally posted by johnboy1313
      Just for a test, unplug the T-Con board and power the set on. Will it power off with the button then? I had a Sceptre X460BV with similar symptoms that turned out to have a faulty T-con board.
      ok so i finally had a chance to do this and with the t-con disconnected it still does not respond to the buttons. so is it looking like main board has a intermittent issue?
      • whatusername
        • Dec 2013
        • 456
        well if i heat the main board with a hair dryer tv turns on 6 out of 10 times with the back off so im guessing main board and am gonna order another one..
        • whatusername
          • Dec 2013
          • 456
          UPDATE: I Got the new main board today from good ol trustworthy Shop Jimmy (Mad Props to them for actually shipping their parts and not lying like another shop) and installed the board and the tv kicked right on.. i power cycled it off and on about 5-6 times and each time it responded.The tv is now remounted on my mothers wall and she is happy its fixed..
          So now we know Main board is the Problem
          I hope this helps someone in the future
          • seekerfine
            • Dec 2014
            I have a sceptre x460bv-fhd8 the power led at the bottom right is red ... the power on button doesn't do anything but i found that with my controler i can turn the tv on and the led turns blue..the Sceptre name turns on as normal then the screen flickers of and the led turns back to red...any ideas????
            • nomoresonys
              • 12274
              • U.S.
              #26
              best to start your own thread, try to post good clear pics.
              • nomoresonys
                • 12274
                • U.S.
                #27
                because people looking at this thread title see the original posters problem and not yours.
                • nomoresonys
                  • 12274
                  • U.S.
                  #28
                  if a shop is sending out bad boards, please let us know which shop, so we can avoid them, the shop can't sue you or nothing, for just telling the truth, thanks.
                  • billyj2times
                    • Jun 2016
                    Hate to bump an old thread but I have the exact same same symptoms on my X425BV-FHD. Unplugging the tcon board makes no difference. I replaced the Power Supply with a new one, no change.
                    My set deteriorated slowly. Started with power up, blue led, have to unplug to power off. usually would come up after several attempts and operate normally as long as you did not power off. Eventually lost all display after being left on for several days while I waited for the capacitor rebuild package. I mistakenly powered it off and it would not come back up.
                    I decided to not tackle the caps replacement because of the heat sinks and my lack of soldering skills. Replaced the power board with a new one - no help.
                    Every thing else described in the thread is exactly the same in my set. Did this turn out to be the main board? I suspect that is what is bad in mine.
                    My daughter has an identical set and it has failed with the same symptoms at about the same age - about 1 year old.
                    Any new info?
                    • billyj2times
                      • Jun 2016
                      Sorry, I did not see the last few responses in this thread. I will replace the main board and post results.
                      • retiredtech30
                        • Jun 2018
                        • us
                        #31
                        yep this is a strange problem just resolved it took a while anyone having this problem where you have pic no sound on the tuner board u will see the big heatsink the main prosesser is underneath take a heat gun on it for about 30 seconds tops. while its hot apply pressure for 5 min the key is to resolder that prosesser do not overheat let cool 15 min before installing may take 1 min before power light resumes.
                        • stu007
                          • Aug 2014
                          • america
                          #32
                          Originally posted by Neonpeon
                          I need some help on this one please.
                          SYMPTOMS: Black Screen
                          I WAS able to get the SCEPTRE screen to come up after it had been off for a couple of hours. Have replaced the Main board. Same Symptoms.
                          Plug it in, I get RED light, Hit the power button light goes blue.
                          I can not power off without unplugging it.
                          I have checked voltages on power supply, they all seem fine.
                          If I unplug the cable from the video board to the inverter, I get backlights.
                          Also I don't seem to be getting much power to the Tcon, not sure where to look here.
                          Hi, I accidentally put thee lvds in wrong and smoked Q7 on the vdeo main board, can someone tell me what it is and suggest a replacement,?? Thanks.
                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                            09-12-2024, 02:00 PM
                          • Chivo77
                            DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                            by Chivo77
                            hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                            1- After receiving power SIO_SLP_S0# goes high and never changes.
                            2-every...
                            07-03-2025, 09:20 AM
                          • JaquesPratt
                            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                            by JaquesPratt
                            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                            07-16-2024, 01:04 AM
                            GeForce RTX2080 Super Aero video gaming card issues help need
                            This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                            Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                            05-07-2023, 08:12 AM
                            HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                            09-06-2024, 06:20 AM
