Hitachi V-1065A Scope Problems...
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Hitachi V-1065A Scope Problems...
    Tom this scope does not support an 100X probe.
    It has fixed input multiplier X1 / X10.
    http://imagine41.com/media/catalog/p...65_010_2_1.jpg
      Doesn't matter. You just mentally multiply the scale by 100X. You could use a 1000X probe too -- though it may be hard to see due to the low output of the probe. 99% of circuits are satisfied by 1X and 10X switchable probes, but the odd higher voltage or higher speed one requires a 100X.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        Either way he can not use this probe, nor mentally multiply the scale, this scope is not even tested or calibrated so to calculate anything on that screen.
          Bullshit... sorry. There is NO calibration. The scope is only ever calibrated for 1X scale but the calibration error will exist only in the probe, there is nothing you can do to adjust scope for 10X and 100X (except maybe 10X multiplier gain, but that is a convenience feature and rarely intended to be as accurate as the main scale.) Probe is intended as non-adjustable except for capacitance which is matched in same way as 10X probe. And do you really think you that the OP requires absolute accuracy? Most oscilloscope applications would be fine with ±10% error in each axis!
          • Spork Schivago
            • Mar 2012
            • 4734
            • United States of America
            Sorry for this question, don't mean to upset you or anything, but why does my scope not support a X100 probe? I bought one and calibrated it all right. I don't understand what a fixed input multiplier X1 / X10 mean. It's a Hitachi V-1065A (with inputs for two probes)
            -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
            • Spork Schivago
              • Mar 2012
              • 4734
              #26
              With my abilities and the first time I've ever used a scope, right now, not even really worried about absolute accuracy. Just figuring out how to use it and actually being able to use it to fix something (like this guitar pedal I got here), I think that'd be amazing. The scope's service manual does have procedures to calibrate the probe by opening it up and adjusting stuff. I do not have the equipment listed to do that though and if anything, I'd pay someone to calibrate it. I think it does need to be calibrated though. I read some wheres that it wasn't worth paying for if you're just a work at home hobbyist. I don't know if that's what you guys are talking about though. You guys are definitely at a different level than I am and I truly appreciate all the help and everything. Thank you.
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                I have three seperate probes, 2 X1/X10 and 1 X100. When I have them hooked up, to get the display all the same size, the X1 is set to .5V VOLTS/DIV, the X10 needs to be set at 50mV and the X100 has to be set at 5mV. Does that mean that the scope does support the X100 probe?
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #28
                  Can I hook my probe up to a 9V battery? Should I see anything if I do?
                    You can. At 2V/div with the trace centered, it should be near the top at 4.5divs from center, assuming you use a 1X probe and you've centered it so with no signal input a flat line appears in the middle of the screen.
                    All a 10X/100X probe does is reduce the input by 10X/100X respectively, whilst also reducing the capacitive and resistive load by 10X/100X, which can be useful for high speed circuits, though probably not important to yourself. All you have to do to get an accurate amplitude scale is mentally multiply the input by 10X/100X, but you can if you wish use the 10X multiplier for the 10X mode. Note that the 10X mode often has reduced bandwidth (e.g. 10MHz maximum) - check the manual to see if it does - hence why it is only used in certain situations.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #30
                      Thank you. I created a small circuit with a resistor, capacitor, LED and then a diode. The electricity flows first through the resistor, then the capacitor, then the LED and then finally the diode. I thought if I hooked my scope up to the cap, I'd be able to see it fire. I could not though. It looked the same either way. When I messed with the TIME/DIV setting, I could slow down the wave and see ridges and everything, like a wave scrunched together. With or without the cap, it looked the same. Not really what I was expecting to see...Also, I'm pretty sick now but I'm still playing with it on and off. If there's a delay between messages, it just means I'm trying to sleep or laying down.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #31
                        Originally posted by Spork Schivago
                        ...I created a small circuit with a resistor, capacitor, LED and then a diode...I thought if I hooked my scope up to the cap, I'd be able to see it fire. I could not though...
                        Sorry, I didn't realize how capacitors worked and I did have my components placed incorrectly into the bread board. It turns out capacitors generally block DC and only allow AC to flow through. I could, I guess, hook it up so when the power is supplied, it'll charge the cap and power the LED until power is removed and then the LED will discharge and power the LED for a bit. That's not what I wanted though. I just wanted to see them fire. Someone told me that capacitors can act like a clock pulse.
                        • Kiriakos GR
                          Banned
                          • May 2012
                          • 940
                          • Greece
                          #32
                          Spork send this bucket to the trash can, and buy a modern one.
                          No matter how stupidly Tom behaves, the bottom line is just one.
                          This scope is not for you, is for some old guys who were dealing with analogue signals which accuracy was never important.
                          If Tom loves it that much sale it to him.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #33
                            So you believe that it wouldn't do me any good? I've never used one and I thought it was a good one for TVs. I read about it on another forum. If I were to get a more recent one, which one would you suggest? What would be the pros to using a newer one vs this one? For example, what can this one not do that a newer one can? Thanks.
                              He is just talking absolute nonsense. He was previously banned from eevblog forum for some arrogant arguments with other members, so I would take anything he says with a pinch of salt.
                              I have a Rigol DS1102E, a fantastic scope but I'm sure WELL past your budget at £300 or around $500. This scope is fine for a beginner. In fact an analog scope is great to learn on. There's no "auto setup" button to press on an analog scope, like on a digital scope. Repeatedly using auto setup means you don't learn anything.
                              A newer digital scope can:
                              - freeze the waveform
                              - automatically set parameters to the right values with one button press
                              - make measurements on the signal (a few analog scopes can do this too) e.g. volts peak to peak
                              - save waveform to memory stick
                              - print out a waveform
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #35
                                ...A newer digital scope can:
                                If that's all, I think this one would be better for me. I need to learn this stuff and this sounds like a good model to learn on. Thanks.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #36
                                  I modified my lit up LED circuit to include a 555 timer. Now it turns on and off. I'm having trouble seeing the wave form though. If I turn the TIME/DIV all the way down, I can see the dot moving up and down but I want to see the wave form whole...when I increase the TIME/DIV, the whole line moves up or down, it's not like the square wave that's on the oscilloscope. What am I doing wrong?
                                  • RON_CET
                                    • 217
                                    See attached this should be what your trying to see and do.The speed at which the LED is turned on and off is set by the values of Ra and Rb.Pin 2 at capacitor showing you charge and discharge rate
                                    Ron Driver,BSEE,CET,ISCET,NESDA
                                      You need to decrease the size of the timing capacitor to get a faster wave, as you're just seeing the electron beam following it.
                                      • Kiriakos GR
                                        Banned
                                        • May 2012
                                        • 940
                                        • Greece
                                        #39
                                        If your plan is to keep working in this field for the next 5 years, you should get a modern one.
                                        The only problem for a 100MHz scope but fast, it is always the retail price, all the called worthy ones are up to 1000 Euro.
                                        I do have a very fresh GDS-2102A and currently I am researching for a good quality 100X probe.
                                        In simple English you started this topic at the same time that my own research is on the go.
                                        The digital scope it can help you to see much detail on screen and measure almost accurately the voltage.
                                        With such a measurement at hand you will be able to compare it with the specified in the service manual.
                                        Simple as that.
                                        • Spork Schivago
                                          • Mar 2012
                                          • 4734
                                          #40
                                          Thanks guys! I will try that. I think I'm figuring this stuff out, slowly but surely.
                                          Now someone said that my probe doesn't support the X100 probe. Is that true? I measured the 555 timer using the X1, X10 and X100 probe. To get the oscilloscope to show up the same with each probe, I had to change the VOLTS/DIV setting. Essentially, the 1X probe with VOLTS/DIV set to 5V shows the same results as the X10 set to 0.5V and the X100 set to 50mV.
                                            HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:44 PM
                                            HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 02:00 PM
                                            HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            HP Pavilion Wave 600-a002la Pavilion i3-6100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave 600-a002la can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a002la boardview and Pavilion Wave 600-a002la schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
