Can i desolder and resolder a buffer chip?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Sadly, I'm thinking the answer is "no" with my limited solder skills and equipment.
    I have a 40 watt iron, a basic weller pot adjust station, and a number of butane torches. Also have some desolder braid, click type solder sucker etc.
    I practiced the torch method on some memory chips, but those seemed to go a LOT easier than when I finally tried to remove one of the buffers on this panasonic sd board. A big problem seems to be the darn silicone they encase the outside of the chip legs with. How can I get it off? caulk remover won't touch it, and it does not melt. It burns badly, and appears to block heat from the torch to the pins.
    I've got two of these SD, and I'd like to swap at least one chip from one to the other, but haven't even been able to remove one yet. Thanks for any ideas, and also any idea on how much heat those chips can take before they are destroyed.
  • capkid
    • Oct 2010
    • 1339
    Re: Can i desolder and resolder a buffer chip?
    I use my finger nail to scrape off as much of the silicone as possible before I attempt a chip removal. Also, I would be very leery of using chemicals like caulk remover on a PCB.
    Swapping chips, especially if there was silicone covering the legs, will be nearly impossible. A hot air station is the best tool for removing the chips, but a heat gun on a low setting can work in a pinch. You need to be sure to protect any nearby components or connectors from the heat, though. I normally use kapton tape, but several layers of aluminum foil might work, also. Installing a replacement chip will be the tougher part.
    Here are some tips: https://www.badcaps.net/forum/showth...light=hp-t5054
    LG Plasma Mal-Discharge Correction Service
    • chappc
      • Sep 2013
      • Uk
      It is possible but difficult. Removing the old ic is the hardest part as it takes a lot of heat to melt the solder ground. I
      I use acetone to remove as much silicone as I can then use solder wick and lots of flux on the legs. Then out comes the hot air gun, start on the other side melt the solder and then bact to the legs just don't damage the solder beds
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        Yesterday, 12:20 PM
      • Yanleb
        Schematic or datasheet for Plasma TV buffer chip
        by Yanleb
        I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
        So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
        Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
        05-18-2022, 01:36 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
