LG 42PX4D-UB No Picture, Sound works
  • gingerbreadman
    • Sep 2013
    • 36
    Hello Everyone,
    I just picked up an LG Plasma 42". As the title says there is no picture but the sounds works.
    At this point I'm thinking it's the IPM on the Ysus board. There was a blown fuse on the ysus board. After having the tv on for a bit the xsus board IPM heatsink was warm while the ysus one stayed cool. The screen seems to be completely black, no flashes, lines or anything.
    What are your thoughts?
    Re: LG 42PX4D-UB No Picture, Sound works
    Y-sus IPM seems likely. Do check buffers for shorts before though.
    • gingerbreadman
      • Sep 2013
      • 36
      Thank you Tom66.
      I installed the new IPM on the ysus board.
      The tv now turns on but the picture only works on the left side of the screen.
      I'm going to recheck all my cable connections.
      Any ideas as to what's causing this?
        Check the cables on the control board are seated properly.
        • gingerbreadman
          • Sep 2013
          • 36
          It works now! I missed hooking up a cable that was hidden underneath another board.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • ex250
            Kenwood SW-505D no sound issue and pops from time to time when it works
            by ex250
            Hello mates,
            I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
            It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
            12-29-2024, 03:27 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
