Samsung A756 LCD problem
  • nodge69
    • Aug 2013
    • 11
    I'm new here - great forum! I've got a strange LCD problem. It's a Samsung A756 40" LCD which is quite a rare model here in the UK though it seems to share components from many other models of the era. It's about five years old.
    I'm in the fortunate position of having access to two of these TV's which were purchased at the same time from the same retailer. They are identical. One is working fine while the other starting exhibiting a completely distorted (random noise) picture. I managed to fix this by applying heat to the left most panel tab. But now I'm left with the issue you can see in my attachments.
    I have systematically swapped boards one at a time with the working TV and there was no improvement. Therefore I know that the TCONN, main board, PSU and all connecting cables are not at fault. No amount of ribbon cable and tab manipulation, heating or cooling will change the picture at all. I have also flexed the panel with no change.
    One other clue - if I remove ribbon cable 3 (counting from the left) the right hand side of the panel goes completely white with no distortion. This suggests to me that each sub pixel can be driven to maximum value correctly from the chips on the tabs. Is my logic flawed?
    Has anybody seen anything like this? I've come so far with the repair, it would be a shame to have to scrap it now. At least I would have spare boards for my other TV I guess!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Samsung A756 LCD problem
    That unfortunately looks like a bad panel. Since you say you have already fiddled with the tab bonds, i'm afraid that is not repairable.
    A working TV? How boring!
      Perhaps the applied heat damaged the bond, I've only ever applied pressure to them.
      • nodge69
        • Aug 2013
        • 11
        Ah that's what I feared. I guess I'll put the boards into the spare parts bucket then!
        Regarding the heat - the effect you can see in my pictures was observed before I applied any heat. I could fix the original problem by applying pressure to the tab, the heat just fixed it permanently.
        Many thanks for your help guys!
          09-07-2024, 05:50 AM
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
        • shlomim412
          samsung ua55es6800 - no image
          by shlomim412
          hi
          having problem with samsung ua55es6800
          tv had backlight on, sound working - responds to the remote control but no image.
          check tcon board - had 12v in but no other voltages present.
          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
          when leaving only left side connected - again no voltages and no image.
          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
          kept trying to block less pins on the left ribbon cable...
          05-15-2024, 05:00 AM
          09-06-2024, 11:40 PM
