Lg 50pc 3d aa
  • Dino61
    • Aug 2013
    Lg 50pc 3d aa
    Hi, TV had the vertical bar problem, but after a couple of times turning it on and off, now nothing at all, no sound or picture. I read a bit, but not enough! and replaced the power board but its still the same.... reading more on here it could be the buffer boards and I should test for resistance ? Got them hanging on the ribbons, but which way do the little clips pull?
    I did disconnect the left and right hand boards and turn it on aagin, but no difference, same with bottom buffer board and both disconnected...
  • capkid
    • Oct 2010
    • 1339
    Re: Lg 50pc 3d aa
    Can you post a pic of that area?
    LG Plasma Mal-Discharge Correction Service
    • Dino61
      • Aug 2013
      Re: Lg 50pc 3d aa
      aah just put it back together to shift it out of the lounge...will do next day or so...thanks for the reply
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Yanleb
        Schematic or datasheet for Plasma TV buffer chip
        by Yanleb
        I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
        So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
        Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
        05-18-2022, 01:36 PM
      • legg
        LG 42PC3 buffer output doesn't follow YSUS
        by legg
        LG42PC3D -UD originally with green lamp but no display or audio.
        Owner says was working, then went 'pop'.
        All 5V caps bulging. replaced.
        All PSU output voltages within spec but -Vy is low on YSUS.
        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
        eventually shorts DG. Replaced all 3 - -Vy now OK.
        Y scan buffer test point does not follow YSUS output below -50V
        Note: This unit seems to expect YSUS output to park at -Vy in between
        drive signal pattern periods. A replacement drive signal board confirms this....
        11-18-2021, 11:49 AM
      • Jidis
        Need T-Con Advice (Vizio P602ui-B3)
        by Jidis
        I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
        He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
        09-22-2025, 05:10 PM
