Sanyo 37" DP37647 HELP with inverted images with ghosting
  • kburks1230
    • Mar 2010
    • 87
    I bought this broken tv off craigslist the other day.
    Any clues what could be causing the inverted images and ghosting on this tv?
    T-con or main board maybe? Any helpful insight would be appreciated.
    See the attached picture.
    -Ken
  • cj_reha
    Mystery 80s Sanyo cap - perhaps polymer?
    by cj_reha
    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
    01-06-2023, 09:24 AM
  • samolo75
    Sony 49XE8096 intermittent ghosting
    by samolo75
    I started posting in a different thread and I was told it was not the best ans the tv model and the fault did not match. I am copping here what I wrote.
    After starting the TV it works ok for a few seconds and then starts showing ghost image with horizontal lines intermittently (except the very top). The frequency of the ghosting is steady, like every second or so, it goes from normal to ghosting every second and back.
    The TV is a 49XE8096. I already did quite a lot of trouble shooting. And I got the doubt if the problem is in the panel or de Tcon.
    When disconnecting...
    02-04-2021, 01:10 PM
  • toddw65
    Sanyo DP5834 - Gray Screen
    by toddw65
    Hey All,
    I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
    Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
    Thanks,...
    10-31-2024, 10:37 AM
  • ojmc
    Hisense 65H6570G - Color inverted after replacing LED backlight
    by ojmc
    Background:
    • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
    • I replaced all 6 of the backlight LED strips with these replacements: amazon
    • The TV worked again perfectly for ~2 weeks.
    • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
    10-17-2024, 02:29 PM
  • j879
    Samsung QLED QN75Q8FNBFXZA inverted/negative color
    by j879
    hi guys,
    My 5 years old SAMSUNG QLED got color inverted somehow. I have tried reset, replace mainboard as well as the driver board without luck. The issue must be on the circuit on panel skinny board or so. For this model I could not find the dedicate T-con board so AS15 replacement is not applicable..
    I have upload the pictures
    Maybe I should measure the gamma voltage but I couldn't find the right place.
    Any idea would be appreciated....
    07-12-2024, 12:23 PM
