Sharp Aquos LC-60LE633U won't turn on, no lights
    Re: Sharp Aquos LC-60LE633U won't turn on, no lights
    Was that with power connected?
    • pmontone
      • Aug 2013
      • 21
      No, no power was connected just using my meter for diode test.
        Sometimes it can be hard to test in circuit and get a reliable result. Anyway, I'm pretty sure the diode is OK. The standby supply wouldn't work if it were shorted.
        • pmontone
          • Aug 2013
          • 21
          OK, thank you very much for the help Tom. I'll try to find a replacement board and post the results.
          • pmontone
            • Aug 2013
            • 21
            I just got my replacement main board in today and put it in and tried to power the TV on and got nothing. I've got the same thing as before the unit refuses to turn on. I wasn't able to find the exact model main board for my TV the one I have is a FM17S and the replacement board is a FM24S.
            • curt196
              • Oct 2013
              • clark
              #26
              just wondering if u got your tv fixed i have the same tv same problem.just wanted to know if yours was fixed and what the problem was thanks.
              • pmontone
                • Aug 2013
                • 21
                I had to replace my power supply. I just bought one on eBay.
                • curt196
                  • Oct 2013
                  • clark
                  #28
                  ok thanks
                  • thetonywarren
                    Sharp 4P-B43EJ2U wont turn on
                    by thetonywarren
                    Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
                    10-01-2025, 09:30 AM
                  • gabrielA7
                    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                    by gabrielA7
                    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                    I saw that the room LED lights up only when the screen is connected, so quiet.
                    We have all the power supplies, even processor, 1.8V
                    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                    I suspect that there may be some leak in the processor.
                    Anyway, when I press the power, it...
                    10-29-2024, 06:48 AM
                  • scubacamper
                    Sharp Aquos LC-70C6400U Half Screen Dark
                    by scubacamper
                    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                    05-03-2025, 12:19 PM
                  • madsox
                    Harman Kardon AVR 171S - standby led lights up, does not turn on
                    by madsox
                    Greetings!
                    Thank you in advance for your understanding, I am writing to you through a translator.
                    A Harman Kardon AVR171S amplifier was given.
                    The history of the machine is as follows:
                    It was faulty when I bought it, I want to fix it.
                    I replaced the HDMI switch and one of the DAC ICs in it.
                    After that it worked without a problem.
                    I watched a movie using the amplifier, and at the end the amplifier got really hot.
                    The cooling was faulty, I will fix this later.
                    I switched it to standby mode, waited for...
                    09-24-2022, 10:46 AM
                  • JunkmanJimbo
                    Sharp lc-55p6000u won't turn on
                    by JunkmanJimbo
                    Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
                    09-28-2024, 12:56 PM
