Samsung LE37B550A5wW Inverter MOSFETs dead short
  • trigger
    • Aug 2013
    • 16
    • uk
    Mosfets on board BN44-00262A have gone dead short. Replaced the two FDPF7N5OU (QI820 QI821) with other mosfets as these were not available. I used FDPF8N50NZF with a better spec and these blew after about 1 sec and took the main 6.3A fuse out as well as the 3,15A fuse which had blown originally. Have i lost drives or something? Any help would be appreciated.
    Re: Samsung LE37B550A5wW Inverter MOSFETs dead short
    You should also replace the components near them which drive the MOSFETs - diodes, resistors, etc. They will connect to the gate pins.
      Also get BN44 number -- I may have a schematic you can use.
        From TOM website.
        the fusible resistor that feed the PFC B+ to those two MOSFETs is OK?
        • trigger
          • Aug 2013
          • 16
          • uk
          Is that PFC out? Cant find PFC B+ on schematic.Resistors round the two Mosfets test Ok.
            Yes that is the same as PFC B+.
            • trigger
              • Aug 2013
              • 16
              • uk
              Thanks for that. I'm trying to source the 4 diodes KDS184, would BAV70 be OK? They are 85V 200mA High Speed switching diodes.
              Will post when Ive replaced the diodes and trannies.
                I can't see why that wouldn't work. Should be an acceptable substitution, given the MOSFET gate is typically driven up to around 10 to 15V.
                • tw2005
                  • Oct 2011
                  • 6458
                  looks bang on target using NXP cross reference.
                  http://www.nxp.com/xref/nxp?typenumber=kds184
                  • trigger
                    • Aug 2013
                    • 16
                    • uk
                    Thanks again. Just removed all the diodes and transistors found one diode and one transistor open cct. Had weird readings around that bit of the cct.Hopefully new bits arrive tomorrow and that will fix it ????
                    • trigger
                      • Aug 2013
                      • 16
                      • uk
                      Replaced the transistors,diodes and MOSFETs .Powered up and the 6.3A fuse blew and the NTC NT811S. Checked for shorts and can't find any. Components I've replaced are OK and the 3.15A fuse. No shorts on the two MOSFETs Q1820,1821. Shall I change the bridge rectifier and the 150uF cap CP815. Strange no shorts? Unless something blew when I first replaced Q1820,Q1821 ?????
                        Do you have a multimeter with frequency and VDC capability?
                        Try powering up with MOSFETs removed, see if the fuse blows.
                          Or remove that fuse (FM802S 3.15A) for the b+ that feeds the two MOSFETs. I have a feeling he may have bad PFC MOSFET (QP801S), or the bridge, or the PFC IC.
                          • trigger
                            • Aug 2013
                            • 16
                            • uk
                            I do have a multimeter and a scope. The Mosfet QP801S does not appear to be short cct or the bridge rectifier. I will replace the bridge and the NTC, remove fuse FM802S and power up and see what happens.
                            • trigger
                              • Aug 2013
                              • 16
                              • uk
                              Sorry about delay in replying for all your helpful advice. Kept on going round in circles with this one. Replaced bridge rectifier and the NTC. Didn't blow the 6.3 amp fuse this time. Still blew the 3.15 amp fuse. Getting expensive, bought another board £40.00. Now working fine.
                              Thanks everyone for your help. Will stay with this forum. Brilliant.
                                09-07-2024, 05:50 AM
                              • Beton
                                Finding a dead short component
                                by Beton
                                Hi guys!
                                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                I have a bench PSU and if I try to inject voltage the voltage...
                                12-10-2021, 01:05 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
