Samsung plazma PS-42V4S 42" vertical lines
  • kivpas
    • Aug 2013
    • 3
    • Europe
    nice forum you got here, i hope that someone can help me about my problem, i purchased PS-42V4S samsung plazma with vertical lines, i noticed that white bright lines are on top of menu and rest is under menu, also when TV is power on lines are barely seen (just this white bright lines, are there but not in that intensity, around 20% of lines are seen), but when tv starts is shows all lines,
    also i noticed in some dark movie scenes there is only this white bright lines, rest of the lines disappear
    Thank you for your time
    Re: Samsung plazma PS-42V4S 42" vertical lines
    Defective plasma panel -- not repairable sorry!
    • kivpas
      • Aug 2013
      • 3
      • Europe
      hm, thanks for the fast reply
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • pni
        LG 49uf695v vertical coloured lines
        by pni
        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
        11-14-2025, 03:15 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
      • polaro
        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
        by polaro
        Greetings,
        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
        08-27-2022, 08:46 AM
