joestevens59
+ More Options
Posts
  • joestevens59
    • Jul 2013
    • 10
    • U.S.A.
    joestevens59
    Hello to you all .new to the site, but i think its a great one, if there was a rating 1 to 10,give it a 10. Have read a ton of these looking for similar problems with a LG 42LC7D-UB,Board #EAY34797001,found a few that were close, but no cigar. Finely took the back off, and found 5 obvious dreaded "BAD CAPS". No pic. no sound, green flashing longer than it should. cycle it on-off, a few times, and bingo would B good. One of those times heard a pop,like a small firework, but each time would take longer. So now i know i at least need these 5 caps witch are,a 35v-1500uf. and four 10v-2200uf. Looked at the master list on this site and the 35v-1500uf is not there. anyone got any info on that.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: joestevens59
    You can get the 35V 1500uF capacitor(s) you need from mouser or digikey.
    What are the dimensions (width, height) of the capacitor? In millimeters please.
    P.S. You really from Amityville? The town with all those haunted houses? :P
    Muh-soggy-knee
    • joestevens59
      • Jul 2013
      • 10
      • U.S.A.
      Re: joestevens59
      Oh, the horror, yeah. I'm not sure on the dimensions,how can u measure?
      • joestevens59
        • Jul 2013
        • 10
        • U.S.A.
        Re: joestevens59
        OH, the Horror yeah, not sure on dimensions, how would u measure?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Re: joestevens59
          Use a ruler that has a millimeter scale.
          For the width, which is actually the diameter since the capacitor is round, you can put the ruler on top of the capacitor and eye-up the size. Common capacitor diameters are 8, 10, 12, 16 mm.
          Some are 12.5 actually, but as long as you get the measurement to within a few millimeters you should be good.
          For the height, take something small and skinny, like a toothpick, and put it next to the capacitor. Take note of the length on the toothpick, and then measure the length of that. Common heights are 5, 7, 10, 11.5, 12, 15, 20, 22.5, and 25 mm.
          Of course, you should measure the distance from one leg of the capacitor to the other leg. These distances are usually either 3.5mm, 5mm, 7mm, and 10mm.
          Muh-soggy-knee
          • joestevens59
            • Jul 2013
            • 10
            • U.S.A.
            Re: joestevens59
            Thanks for the advice, was about to try your recommendation when i read your message, sorry it takes me so long to respond, i"m a two finger type"r, than it hit me to dig up my calipers.
            • joestevens59
              • Jul 2013
              • 10
              • U.S.A.
              Re: joestevens59
              Also that last part about the leg distances, thanks, but will it be a problem?,. have"t taken them off yet.checked Digikey and not sure on all they ask like tolerance,lifetime temp.,ripple current,ohm"s,ect.
                Re: joestevens59
                Tolerance: always +/-20%
                Lifetime: ignore for now, mostly irrelevant except when comparing two capacitors
                Temp: always 105C
                Ripple current: ignore for now, mostly irrelevant except when comparing two capacitors
                Ohms: (ESR) choose Panasonic FM, FR, or FC and you will be fine.
                • joestevens59
                  • Jul 2013
                  • 10
                  • U.S.A.
                  Re: joestevens59
                  You were on the money. Have all the measurements so i can now answer your question. They R as follow"s 35v-1500uf W-16mm, H-25mm , Leg Distance 7mm.. All Four 10v-2200uf are W-12.5mm, H-20mm..Leg Distance 5mm.
                    Re: joestevens59
                    Check height will fit:
                    1500uF 35V
                    http://www.digikey.com/product-detai...447-ND/2433581
                    2200uF 10V
                    http://www.digikey.com/product-detai...1189-ND/356094
                    • joestevens59
                      • Jul 2013
                      • 10
                      • U.S.A.
                      Re: joestevens59
                      THANK YOU, NO SINCERELY THANK YOU. I am knew to this site, still trying to figure it all out. I don"t mean to break any rules or piss anyone off, and it"s not just being new to this site, but i"m not to proud to say i"m not a computer savant, witch i would gather you all are already aware of,the reason i say all is because you(tom66) as well as ben7,and topcat i feel without needing conformation ,are savant in this field, and have my respect, and once again i would like to THANK EACH OF YOU FOR YOUR HELP AND EXPERT TECHNICAL ADVICE if there is a way that you can forward this to them(or-and post it for the masses ) i would appreciate it, and to the masses i say these guy"s are ace"s. On a separate note both you and topcat added the don"t PM me, put on public forum, apology"s to you both, as it is said "the only stupid question,is the one not asked", so that being said to post on public forum that would be the post reply bottom left corner of this window?
                      • deviantcode
                        I have a thinkpad p1 gen 3 20th-ct01ww. Recently I've had 2 that after windows updates, it no longer detects the battery
                        by deviantcode
                        I have a question regarding one of these lenovo laptops. I have a thinkpad p1 gen 3 20th-ct01ww. Recently I've had 2 that after windows updates, it no longer detects the battery. I have tried rolling back the bios update and that didnt fix it. Is this something that requires modifying the original bios to fix or is it bios related at all ? Is this issue common. thanks.
                        01-31-2025, 08:56 AM
                      • aprilmixtape
                        Asus Tuf Dash F15 (FX516PC Rev 4.0) IC chip no longer able to be read
                        by aprilmixtape
                        I recently ordered a CH341a to try and fix my 2021 Tuf Dash F15 after seeing a video about Asus laptops being diagnosed as having fried mobos when they have corrupted bios. After following the steps from a YouTube video and flashing the IC chip (W25R128JVSQ; detected as a W25Q128BV on AsProgrammer) the laptop booted up for the first time in 2 years. I looked around my room for the M.2 drive I had removed from it and as soon as I came back the laptop had turned off. I assumed it automatically turned off due to inactivity but when I pressed the power button, the backlight and power button would...
                        12-18-2024, 10:02 PM
                      • Gamerfreak_LP
                        I can no longer access the bios as an admin
                        by Gamerfreak_LP
                        Hello first,
                        I have a problem. I can no longer log into my bios as an administrator. I had created a user account in the bios so that I can start the PC normally and an admin account to manage the bios. Without admin access it is not possible to change the boot sequence or the like. This was actually intended as security in case the laptop was stolen or I lost it so that nobody could access the data. I had saved the password on a YubiKey 5c. This normally just entered the password bluntly when I pressed the button.
                        But now the mainboard tells me that this password is wrong.
                        Do...
                        10-02-2024, 01:59 PM
                      • quedijo
                        Lenovo Legion 7 15IMH05 - No Longer Power Ups
                        by quedijo
                        Lenovo Lenovo Legion 7 15IMH05
                        Model Name: 81YT
                        Serial Number: MP1XJQ9J
                        MB M#: FLY00 LA-J561P Rev:1B
                        I have the laptop in the title and have had it for about 5 years. Was mine and shared it with my kids for about 2 years, then a year of just the kids and last year just my son. He plays on it about 8 hours a day. We regularly make sure to clean out the blower and heatsinks.
                        About a year ago the screen started to act up. Sometimes coming on, sometimes not. Sometimes "bowing" the screen would get it going. About 8 months ago bottom side of the...
                        07-01-2024, 02:33 AM
                      • Pasglop
                        Asus X421EA no longer starts
                        by Pasglop
                        Good morning
                        I am encountering a problem on an Asus X421EA card which no longer starts; I checked the voltages, the 5v and 3vd are missing, has anyone encountered this problem, I have been looking for several hours without finding the source of the problem. Thank you!​
                        05-03-2024, 02:27 AM
