TV Problem Samsung PS50C490 Plasm 3D Led Light 5 times
  • Gilera001
    • Jul 2013
    • 75
    • Deutschland
    Hello, I have a problem with my Samsung PS50C490 Plasma 3D TV, when I turn on the TV and the LED blinks 5x Clicking
    the power supply after every click I can hear 3 little noise from the power supply. If I go the plug (Picture 2) abmache the
    TV on dark image and sound, and when I abmache the plug of (Picture 3) exactly the same. I have also all
    Flat Cable agreed by the Panel error remains (LED FLASHES).
    Does anyone have an idea?
    Sorry for my bad english but i hope u can help me =)
    Picture 1
    Picture 2
    Picture 3
  • Gilera001
    • Jul 2013
    • 75
    • Deutschland
    Re: TV Problem Samsung PS50C490 Plasm 3D Led Light 5 times
    Have nobody a Idea?
      We can't see your pictures -- try using the "Manage Attachments" feature of this forum.
      • Gilera001
        • Jul 2013
        • 75
        • Deutschland
        Oh Thanks my Mistake =)
          Is the clicking sound a faint "ticking" or the normal clicking that used to be heard when turning on the set?
          • Gilera001
            • Jul 2013
            • 75
            • Deutschland
            Thanks for the reply, I have made a video about the error.
            it sounds like three little sounds coming from the transformer at 0:14 Sec
            I Hope u can help me =)
            Video
            http://tinypic.com/r/wiwobt/5
              Sounds like it may be a main board fault.
              Isolate the main board power indicated in the photo below.
              Then follow the steps in this post:
              https://www.badcaps.net/forum/showpo...61&postcount=2
              Do you get test patterns?
              • Gilera001
                • Jul 2013
                • 75
                • Deutschland
                Hello, ok i have do this but the mistake is the same it´s clicking 5 times
                  Clicking, or the light is blinking?
                  • Gilera001
                    • Jul 2013
                    • 75
                    • Deutschland
                    ÃŽt is Clicking ,the Panel is black, and the Board ( From Thread #8) is Blining Green...
                    • Gilera001
                      • Jul 2013
                      • 75
                      • Deutschland
                      Can the mistake come from the yMain and buffer? Or from the power supply? I want my tv back its really bad with a 19 inch tv
                        It is either Y-Main or X-Main or Power Board.
                        You need to connect all boards as usual, then try with Y-Main unplugged (from power board only) and see if symptoms change. If they don't try with the X-Main. If they still don't it's likely to be a power board fault.
                        • Gilera001
                          • Jul 2013
                          • 75
                          • Deutschland
                          I have testet it, when i unplugged the power cord vom the y-main to power suply the tv go on and i hear the sound but the tv panel is black. Have i a defect ymain?
                            It would seem like it.
                            • Gilera001
                              • Jul 2013
                              • 75
                              • Deutschland
                              Ok thanks tom66, it is a normal mistake that the tv is clicking and blinking when the ymain are defect faulty? I have only read that the tv makes lines when the ymain are defect
                              Pls respown greetz
                                What you have read is incorrect; Y-main defect commonly results in the power supply going into "protect mode", which causes clicking sound.
                                • Gilera001
                                  • Jul 2013
                                  • 75
                                  • Deutschland
                                  Today I installed a new ymain he also goes to has only had red dots and dashes image error have then chosen from the menu on eco mode then it has popped and the picture is black! Now comes a picture for 1second after power on
                                    Did you replace the X-main too? Both may be defective...
                                    • Gilera001
                                      • Jul 2013
                                      • 75
                                      • Deutschland
                                      Yes i have the xmain board changed
                                        But both at the same time?
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
                                        • slimsoul
                                          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                          by slimsoul
                                          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                          03-12-2024, 03:55 AM
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
