Samsung 42" Plasma PN42C450B1D
  • fatcattara
    • Feb 2014
    • 42
    Re: Samsung 42" Plasma PN42C450B1D
    I do have a multimeter available
      Great, can you see if you can test the VS voltage from the power board, with everything as it currently is? It should be around 200V. Red probe on test point, black probe can go on the metal chassis for ground.
      • fatcattara
        • Feb 2014
        • 42
        Is that from the big pin on top of the power board? If so - it's 0V
        • fatcattara
          • Feb 2014
          • 42
          See picture for test point used to chasis
          http://i34.photobucket.com/albums/d1...ps2995753b.jpg
            That's the correct point, so, does that change at all as the TV clicks on and off?
            • fatcattara
              • Feb 2014
              • 42
              no, it did not
              • tw2005
                • Oct 2011
                • 6458
                try this, remove power cable from ymain CN5000 or CN804 at PSU. Have the probes connected, then try again. It may come up briefly and then disappear.
                • fatcattara
                  • Feb 2014
                  • 42
                  Once I removed the x/y power cable, the green LED stayed on, the relay just clicked once and the Voltage went up to 209V and dropped down to less then 1 V
                  • tw2005
                    • Oct 2011
                    • 6458
                    looking very much like almost every other one of these with an xmain failure. On the Xmain, there's a single heatsink. The outermost transistors either end marked XS,XG ( the other numbers are too small for me to read) set the meter to continuity and probe across any 2 legs of both of those and tell me if they are shorted.
                    • fatcattara
                      • Feb 2014
                      • 42
                      non of them were shorted - I plugged the left High voltage board to the power supply (kept the one on the right off) and when the relays cycled, the voltage went up to 200V
                      • tw2005
                        • Oct 2011
                        • 6458
                        Well even though they're not short, could be something else on the Xmain, you've had a clear change. You could always hook it back up and repeat the vsus check and confirm multiple clicks and nil voltage showing at all ever.
                        then the hard bit is what to recommend. I took the least risk higher cost option of purchasing the 3 boards because they are really cheap to get and I've read y's being killed by the X and I'm pretty sure I stuffed my y trying to repair the X.
                        My buffer was ok which I checked with the replacement so i could have skimped there.
                        The 3 at SJ are about $90 but i got mine through payless components and got them much cheaper.
                        that was last year, not sure if he still has any or how cheap.
                        See what Tom reckons, some progress made.
                        • fatcattara
                          • Feb 2014
                          • 42
                          Thanks for your great help - have a g'day mate
                          • tw2005
                            • Oct 2011
                            • 6458
                            Ha, Ha.
                            I might go and put a kangaroo on the BBQ. (joke)
                            • Lokidoki
                              • Jul 2014
                              • 4
                              • Murica
                              #94
                              Hello. I am having a similar issue with the same model television. Samsung PN42C450B1DXZA.
                              It worked perfectly for years but just recently I went to turn it on and I just hear a few clicks as if it is trying to turn on, then just stops. Never any sort of picture or sound. I have researched a tiny bit and it seems Samsung plasmas are notorious for bad capacitors? I have never seen bad capacitors. Should testing for those be my first step? How do you tell that a capacitor is bad? Is it warped or something? If someone wouldn't mind giving me some pointers there I will take it apart and check her out. It's been unplugged for a couple weeks at least.
                              • Lokidoki
                                • Jul 2014
                                • 4
                                • Murica
                                #95
                                Sprry about the blur on a couple of them. Took it apart and checked it out. Again, idk exactly what a blown capacitor is supposed to look like, but I didn't notice anything that looked burned or warped or destroyed on any of the boards. Are there certain ones I am supposed to be checking for? Am I just missing it?
                                So assuming it isn't a capacitor issue, what else could cause the problem? I will update shortly with a video of what happens when I try to boot the TV up. I am about to go and re-seat all cables and check again for anything that looks out of the ordinary and then will plug her back up to record.
                                • Lokidoki
                                  • Jul 2014
                                  • 4
                                  • Murica
                                  #96
                                  https://www.youtube.com/watch?v=17nZEFpaKnw
                                  This is me trying to turn it on, getting a blinking light and clicks. I then try to use the remote and only get a slight blink of the light when I hit the power key.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #97
                                    Lokidoki
                                    There is a whole thread on what bad caps look like
                                    https://www.badcaps.net/forum/showthread.php?t=424
                                    Next you need to start reading this thread from the beginning and do some of the tests
                                    reporting the test and result.
                                    When removing boards or cables switch off and unplug and leave 15 minutes or so between each plug in.
                                    Also if you click on troubleshooting tvs and video sources above in the stickies there is a good guide by Tom66 on how to test a plasma tv
                                    https://www.badcaps.net/forum/showthread.php?t=18542&
                                    • Lokidoki
                                      • Jul 2014
                                      • 4
                                      • Murica
                                      #98
                                      Sorry I don't see that sticky, only the LED/monitor sticky by someone else. Will search for that thread now.
                                      • lemo5617
                                        • Jan 2015
                                        • 5
                                        • canada
                                        #99
                                        Hi i have the same model and my problem is black horizontal lines on the middle of screen...should i change the buffer board...
                                        • juke175
                                          • Jun 2016
                                          Hi guys, Newbie here. First of all, many thanks for your help! I also have a Samsung PN42c450b1d, model code pn42c450b1dxza. The upper 1/3rd of the screen is dark. The bottom 2/3rd of the screen is fine. All functions (sound, etc) work fine. Any suggestions? Thanks in advance for your help!
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
