Samsung 42" Plasma PN42C450B1D
  • fatcattara
    • Feb 2014
    • 42
    Re: Samsung 42" Plasma PN42C450B1D
    I meant the main power board - sorry about the confusion
    • fatcattara
      • Feb 2014
      • 42
      I've done the "wiggly" to ensure that that was not the case - cables were OK. Funny, this morning I had a proper picture
      • fatcattara
        • Feb 2014
        • 42
        http://i34.photobucket.com/albums/d1...ps13e7114e.jpg
        Done the control board again as per instruction
          You undid the wrong cable; the LVDS cable is the one on the top near that header. That also explains your pink picture as the lack of an X-main drive would lead to a pink image on the plasma panel (due to poor plasma panel gas discharge.)
          Those ribbon cables are hard to insert and align, so make sure you get that right.
          • fatcattara
            • Feb 2014
            • 42
            Ooops - my blond moment....
            Update: all colors came back - I have right now a proper picture and will let the set run for the next hour
            If it fails again I will redo the test as per your instructions (and unplug the correct cable)
            • fatcattara
              • Feb 2014
              • 42
              The set run fine for 1 1/2 hrs - when I checked, the video was gone again. After powering off (unplugged the cord) in order to run suggested test, I was unable to power up. The relays clicked on and off again and wouldn't permit me to power up. I used the remote as well as the switch on the frame. Game over?
              • fatcattara
                • Feb 2014
                • 42
                I checked both fuses - they are OK; still unable to turn the set on after being disconnected for 12 hours with remote or manually (
                • fatcattara
                  • Feb 2014
                  • 42
                  Thanks for your efforts Tom, I'll make sure the set gets recycled
                    Don't throw it away yet!
                    There is one further test but you need to get a pair of 100 to 470 ohm resistors...
                    • fatcattara
                      • Feb 2014
                      • 42
                      Will have to get them - go ahead please
                        You want to unplug the main board power connector completely; this is the connector which hooks the main board to the power supply.
                        Then connect one resistor between PS ON and GND, and one between VS ON and 5V standby. The power supply should turn on, indicated by one or two clicks. If it does, unplug it. Then apply the 4-3 jumper and see whether you get test patterns on the screen.
                        • fatcattara
                          • Feb 2014
                          • 42
                          If this is the correct board, where do I find PS ON and VS ON
                          http://i34.photobucket.com/albums/d1...ps89de05c6.jpg
                            That is the correct board, the pins should be labelled in a legend near where they connect. If not, will have to look up fast track guide.
                            • fatcattara
                              • Feb 2014
                              • 42
                              You were referring to those ID's?
                              http://i34.photobucket.com/albums/d1...ps4340c67b.jpg
                                Yes but in your case the ones that go to the main A/V board - i.e. the one with the video inputs on it - not the X- or Y-main boards...
                                • fatcattara
                                  • Feb 2014
                                  • 42
                                  Questions to clarify: do I leave the connector to the x & y boards off? Do I leave both plugs off (see picture)? And last - both plugs have PS ON and VS ON; do I use upper or lower?
                                  http://i34.photobucket.com/albums/d1...ps742e2d60.jpg
                                    Use the upper connector.
                                    Everything except main board power and the main board LVDS to be connected.
                                    When I refer to main board, I mean the board with the tuner, HDMI, video inputs, etc...
                                    • fatcattara
                                      • Feb 2014
                                      • 42
                                      To clarify: I test (use the resistors here) on the upper connector (that's the one going to the tuner etc. and leave also the lower connector off (cable going to the board for the test pattern)
                                        You want to leave the cable marked BN96....... off.
                                        You want to unplug connector between main board and the power board, but unplug it on the main board end, and stick resistors in the exposed holes.
                                        Everything else as normal.
                                        Once you have done this post a picture so we can see if it's all correct.
                                        • fatcattara
                                          • Feb 2014
                                          • 42
                                          Hey Tom, here is a picture of the tuner board
                                          http://i34.photobucket.com/albums/d1...psd4716290.jpg
                                          And here is a picture of the board with notation for the resistor placement
                                          http://i34.photobucket.com/albums/d1...ps79392dcd.jpg
                                          I hope I got it right
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
