Schoolboy error with solder paste
    Re: Schoolboy error with solder paste
    Probably, you could trace it and find out for sure.
    Schematics
    http://www.tgohome.com/ServiceManual...h=Submit+Query
    Looking at the design, it uses transformer isolation to drive the FETs so it's probably only those two FETs plus associated resistors/diodes bad, controller IC may be OK.
    • signup
      • May 2013
      • 189
      Thanks so much Tom, just one more question the fet that blew was a 9a500v N, Ihave only got 11a 600v N's spare...that will be ok wont it
        Check the Qg is the same or lower... google the specification for both... and if so you should be OK.
        • signup
          • May 2013
          • 189
          Qg on 9n50c is VDS=400v Typical =35
          Qg on 11n60C3 = VDD=480v Typical=45
            Not ideal... but close enough that it's unlikely to cause problems. Higher Qg essentially means more heat produced.
            • viewerau
              Remove excess solder
              by viewerau
              Can someone tell me how (or if) I can remove this excess solder?
              I made a novice boo boo.
              The board is an edge board from an lcd tv, and it connects to the tv panel via a fixed cof strip.
              I had to remove a surface mounted multi diode chip (yes I did a bad job) but got some residue solder on the pins when cleaning it up with a ribbon wick.
              Can I get that excess off, as I believe it is causing interference to the panel, shorting or something, that effects just a small portion of my image.
              Any pointers please?...
              08-16-2023, 03:52 AM
            • dicky96
              Solder paste recommendations please
              by dicky96
              Hi guys. Well I thought solder paste was just solder paste but apparently not
              I watched this short video
              https://www.youtube.com/watch?v=uSb1fgCMUug
              I want to try solder paste for resoldering BGA chips and LGA sockets as I am having no luck at the moment. I have no problem safely removing the old part, it's getting the replacement one to solder which is where I am going wrong. The Type 5 solder paste link he gives in the above video says it is not available.
              I want to use the paste like in the video on this thread
              https://www....
              05-11-2020, 03:31 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • menshawy
              Question about solder paste vs solder balls
              by menshawy
              hi friends
              what about using solder paste to reflow vram because it is easier than solder balls
              but it will working perfectly or it will die after short time ?
              I need your experience
              thanks
              12-04-2021, 07:49 AM
            • Veyron7887
              Laptop overheating after replacement thermal paste
              by Veyron7887
              Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
              11-24-2024, 05:08 AM
