SAMSUNG PS42C451B2D No picture,no sound - fixed
  • tw2005
    • Oct 2011
    • 6458
    Hi, Picked up a Samsung PS42C451B2D plasma TV. Usual deal, shuts down, no picture or sound. Logic board quits with a slow blink indicating failsafe.
    Disconnecting Xmain, could get powerup and sound, then tried replacing the IGBTs only xmain, blew them, killed Ymain, buffer seemed ok.
    researching this forum, there's a few posts especially the RCA 42PA30RQ, same panel and boards.
    Pretty clear reading them the only sure way to nail this is the Xmain,Ymain,Ybuffer swap otherwise it appears you simply waste time and money blowing boards.
    Did this, sure enough, it works. as it turned out the buffer was fine so only really needed the others.
    Firmware upgraded to 1024 (was 1023), not sure if this is worldwide firmware but this was Australian model.
    I got the parts real cheap from payless components, he's since cleared out of the ones from the RCA & Viore brands which is no surprise since the X was about $11 and the Y about $13. If you searched only by samsung it would have been much more but they're the same. Buffer was $30, pitty I did not have the courage to trust mine otherwise would have been a working set for under $100.
    Have to admit I'm not a Samsung fan but does have very good picture and reasonable sound with media player ability as well.
    Below is some other models shown as the same panel and boards.
    ybuffer LJ41-08594A LJ92-01739A (sticker 739c)
    xmain LJ41-08591A LJ92-01736A
    ymain LJ41-08592A LJ92-01737A
    ELEMENT
    ELPCFT421
    INSIGNIA
    NS-42P650A11
    RCA
    42PA30RQ
    SAMSUNG
    PN42C430A1DXZA, PN42C450B1DXZA, PS42C450B1WXXU
    VIORE
    PD42VH80
    Panel Sticker Number:
    S42AX-YB09, S42AX-YD13
    Panel Manufacturer:
    Samsung
  • capkid
    • Oct 2010
    • 1339
    Re: SAMSUNG PS42C451B2D No picture,no sound - fixed
    Yeah, board swapping is the way to go on these TVs. I tried to get cute by changing out the IGBTs on my first couple Samsungs of this ilk, and I ended up in TV repair hell.
    LG Plasma Mal-Discharge Correction Service
      Same experience myself -- I've actually only found some with shorted IGBTs. Most I couldn't actually track down a fault.
      • tw2005
        • Oct 2011
        • 6458
        i did not think this one had any at first, sometimes I think i'm losing my mind but very soon after both had shorted transistors,
        • tw2005
          • Oct 2011
          • 6458
          I think it was this one that was pretty convincing. I was quick to call it quits this time for board repair.
          Your Y-main may have been damaged by the faulty X-main; the part you got on eBay was probably fine...before it was installed in your TV. It probably got damaged by the Y-main, which was probably damaged by your original X-main. It can become an infinite loop. Trust me, you need to be very careful when testing these particular TVs. I'd do most of the testing with a meter and skip the voltage tests in relation to the mains. I'd only test the power supply with none of the mains connected to it.
          Edit: Again, you may be looking at replacing the Y-main, Y-buffer, and X-main ALL AT ONCE again to get it working.
            Combined energy recovery + very lackluster IGBTs (like maybe one for each main switch portion; Panasonic use 2 or 3.)
              09-07-2024, 05:50 AM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • howardc64
              Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
              by howardc64
              TV was fixed just after removing Samsung's rear snap cover.
              This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
              Maybe PSU->backlight connector didn't have a good contact?...
              07-23-2025, 12:34 AM
