Samsung TV 5 blinking lights
  • dday2222
    • Jun 2013
    • 16
    • US
    Re: Samsung TV 5 blinking lights
    So the probability of it being a problem with my tcon is very likely?
      I'm not certain it's t-con, I would think main board.
      • dday2222
        • Jun 2013
        • 16
        • US
        Im taking it to a shop, thanks anyway.
        • XmouseX
          • Aug 2011
          • 158
          • US
          We should have a sticky that says - Unless you have a voltmeter, do not open your TV
            Good luck with the repairs. Hope you get lucky and get a competent shop. Many aren't.
            • dday2222
              • Jun 2013
              • 16
              • US
              #26
              I spoke to a repair man over the phone and he said it sounds like a main board problem also. He said since he hard time looking for a main board at the places he usually finds things, that its most likely the problem. Im taking it to him tuesday and he said it should cost $150 to fix, so im going to try and do that. Only $25 to look at it and figure out the problem.
              • BassManMike
                • Aug 2014
                5 blinking red lights no Caps bad, tech says it has a power issue, oredering power board tomorrow.
                • Sorin.
                  • Nov 2017
                  HI everyone , i got my Samsung LE32A557 with the standby light blinking 5 times and then stops, i have disconnected the LVDS cable but no response ,(no light nothing) when i press buttons on remote the red light seems to respond , i also want to mention the caps looks ok and seems to be replaced before , im not first owner , any ideas ? thank you
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    Any photo's of your boards. Any voltage readings from the connectors to the main board?
                    You would be better off starting a new thread since this thread deals with a different model
                    • John K
                      • Jun 2018
                      I have a similar issue. 5 blinks on my Samsung 55" then the screen is black (very dark navy blue) with no sound. The backlights are on since I can see them with the back cover off. There are no images in the screen even when I use the flashlight test. I've even changed the T Com, Power & Main boards with no luck. Not sure what else it could be?? Any help is appreciated.
                      • John K
                        • Jun 2018
                        DDAY2222
                        Did you ever get your TV working?
                        • onlyloco
                          • Nov 2015
                          • 6
                          Hi everyone! Need some help. I'm going crazy over here. Does anyone know where F2 is on this board?
                          https://cdn11.bigcommerce.com/s-v5cp...269128.jpg?c=1
                          • nomoresonys
                            • 12085
                            • U.S.
                            #33
                            Are you sure there's suppose to be a F2, most tcons have one fuse.
                            • onlyloco
                              • Nov 2015
                              • 6
                              I’m not! maybe that’s it. I see F1 with a fuse and F3 empty, maybe there is no F2. I was not able to find a diagram for it.
                              • nomoresonys
                                • 12085
                                • U.S.
                                #35
                                What are your symptoms?
                                • onlyloco
                                  • Nov 2015
                                  • 6
                                  Tv power light just blink 5 times and screen stays blank, there is no backlight or image. I replaced power support supply and same issue exists.
                                  • onlyloco
                                    • Nov 2015
                                    • 6
                                    Any suggestion what to check next?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #38
                                      remove the cable between the power supply and mainboard do the backlights now come on
                                      • onlyloco
                                        • Nov 2015
                                        • 6
                                        wow never knew to try that, thank you. Yes backlights came on.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          mainboard issue then i ususlly just replace them if cheap enough
                                            09-07-2024, 05:50 AM
                                          • bialag
                                            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                            by bialag
                                            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                            03-25-2025, 05:56 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
