Bush IDLCD37TV25HD
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Bush IDLCD37TV25HD
    Hi i have a bush lcd tv set model,IDLCD37TV25HD,it has sound but no picture,well not one that will stay on for long,it has not been my set so just going on what is happening now,on switch on see the screen light up for a matter of seconds,but does have sound.
    So could i please have some tips on what to test,look out for etc,i will put up pictures when i get the set opened up
    Many thanks.
    Re: Bush IDLCD37TV25HD
    Common fault on these is two bad 450V capacitors, very obvious when you open it up.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Thank you tom,i will report back.
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Found x3 raised caps 1000uf 16v,the 470uf looked ok but not tested.
          While they weren't the ones I was expecting, these too can cause problems.
          I would, at a minimum, replace all of the green and gold CapXon.
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Ok,would you advice changing the 470uf caps and also what caps would you advise buying,have seen various on ebay.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              the green/gold bigger cap,looking at it it says 1000uf,but cant work out if it says 50v or 150v,any ideas.
                It'll be a 50V cap in that position.
                Use Panasonic FR, FM, FC. Try to buy FR or FM over FC, but all three are good capacitors.
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  Changed the capxon green.gold caps with slight buldge,no change in the way the set fires up still a light flicker then off again,i can not seem to find the two 450v caps you suggested,the only two are 4500uf 6.3v caps ?
                    I was in error suggesting those 450V capacitors, as this is a VESTEL not MEGMEET/PROVIEW.
                    What you need to do is check the 24V, 12V, 5V and 3.3V the power supply is producing. Check in standby, and when it's running. In particular, if the 24V is too low, this symptom may be seen. However, if the 24V is good, then we need to look at the inverter board. I have fixed a similar 37" DIGIHOME (probably the same TV inside) with similar symptom, bad inverter transformer, easily fixed.
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      The board is a 17pw15-8,if thats any help and you advice me checking the voltages please.
                        Yeah, I know 'em all too well. Do the tests I suggest and then we can see if power board or inverter are at fault.
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          tom could you highlight on my photo where to test please
                            Just test all of the connectors on the power board, red probe on each pin of each connector, black probe on chassis, DC 200V range.
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              ok,with the set in standby and on ?
                                Yes, both states.
                                • scouse1215
                                  • Sep 2013
                                  • england
                                  Hello lads did you ever get to the bottom of the problem as i hveexctly the same fault... cheers...
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:30 PM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
