Samsung model PS50A556S2FXXU TAKES LONG TO TURN ON
    Re: Samsung model PS50A556S2FXXU TAKES LONG TO TURN ON
    The connector is still loose then, the only way to fix this would be to ask the seller to exchange the control board.
    • comrade gibby
      • May 2013
      • 31
      • united kingdom
      #42
      I think you're right, I'll try to contact him tomorrow, Thanks Tom66, you're a man of good heart, very rare to find these days, May the Lord bless u.
      • comrade gibby
        • May 2013
        • 31
        • united kingdom
        #43
        Hi Tom, I was going through your wonderful plasma troubleshooting today, I note one thing there and thus the issue of sound. When I was removing the parts I replaced and putting back the old original ones, original logic board, PSU, and the Z-sustain board, I heard the welcoming sound from the TV but no picture; it could just flip as if the picture could show up but it fails. The other thing is when I disconnect the main connector between the PSU and Y sustain board, there is no sound, not even flipping. Any idea sir?
          Flipping? What do you mean?
          • comrade gibby
            • May 2013
            • 31
            • united kingdom
            #45
            Sorry my English, something like flushing as if picture will come on, sir
              I'm not sure what you mean. Flashing? Have you fixed the loose connector yet?
              • comrade gibby
                • May 2013
                • 31
                • united kingdom
                #47
                I tried to fiddle around but still giving the same probs, so I just put back the same old one. What I mean is that the screen brightens as if it could turn on but it fails.
                  If the symptoms are different, it must be the control board at fault.
                  • comrade gibby
                    • May 2013
                    • 31
                    • united kingdom
                    #49
                    Ok, any idea where I could find a new part for this tv please? thanks Tom.
                      Use the LJ9x-xxxxxx number on the board and order on eBay, flattvparts, etc.
                      • comrade gibby
                        • May 2013
                        • 31
                        • united kingdom
                        #51
                        Hi Tom, I tried to google the company but the parts are out of stock. If there is another one please let me know. Also the word flashing I meant blinking.
                        Thanks once again.
                          eBay? Don't know of any others ATM.
                          • comrade gibby
                            • May 2013
                            • 31
                            • united kingdom
                            #53
                            Ok, tried ebay but none, anyway I will keep on search, thanks very much Tom
                            • comrade gibby
                              • May 2013
                              • 31
                              • united kingdom
                              #54
                              Feedback on Samsung model PS50A556S2FXXU TAKES LONG TO TURN ON
                              You have a temperature sensitive problem. As temperature rises something gets hot enough to drift into operational characteristics, and the TV can work.
                              Therefore, I suggest when (not if) it fails, you take the cover off, and start heating parts of the power supply and main board. You can use a household hairdryer for this. If this makes it work, you have found the part which is faulty, and you can replace it or narrow in on the individual components. Main board failure is most common on these models.
                              Hi Tom and all members,
                              I think today I have identified the problem of my plasma. After battling all these days with my TV, today I tried to go by Tom's idea to heat the logic or X board, and then BOOM the TV turned on. I observed it by leaving it for some time. Then it turned itself off. I tried to switch it on without heating the logic board, it couldn't turn on. I heated the logic board again (all this time using the hair blower), then it turned on. I then plugged in all cords (sound, sky etc), and the TV is working normally.
                              So, to conclude that the logic board is fault and need replacement, could it be wrong? Please advise me.
                              Thanks Tom for you advice of heating components.
                                Yes, that is where I would be focusing on. Do double check all connectors are seated properly.
                                • comrade gibby
                                  • May 2013
                                  • 31
                                  • united kingdom
                                  #56
                                  Thanks Tom for being there for me. I will try to order a new one whilst still observing the TV. Once again thanks
                                  • jagg
                                    Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
                                    by jagg
                                    Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
                                    Here are the bios and the schematics.
                                    Could someone help me verify that the bios is correct? thank you so much !!...
                                    11-22-2023, 03:36 PM
                                    HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                    This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                    09-06-2024, 05:27 AM
                                    HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  • PNI E.
                                    Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                    by PNI E.
                                    Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                    03-17-2025, 04:23 AM
