panasonic TX-P42S10B 5 blinks
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: panasonic TX-P42S10B 5 blinks
    Did check for short on P35 p1/2 no short, p5 on P25 again no short this is with the Sc out of the set but every thing else plugged in but the SC buffers. This sos code thing can and will drive you mad,If it was a TNPA5081 it would be Ok as i have one of them, no one seems to have a TNPA4829 just have to hope i can repair it.
    • tw2005
      • Oct 2011
      • 6458
      Anything's possible, certain parts of the cct are comparable with the 5081.
      You may be lucky and it's just blown IGBTs but that was not the case in any of the 5081 I fixed.
      If you have not read it, you may get something out of it. Highlights some of my mistakes and what can happen when you miss things and power it up.
      long winded but I did sort them out in the end.
      https://www.badcaps.net/forum/showthread.php?t=26322
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
        11-20-2024, 08:52 PM
      • Biruslapio
        Panasonic P58V11B 8 and 12 blinks error "fix"
        by Biruslapio
        Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
        Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
        04-13-2021, 07:13 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
      • CrewmanRedShirt
        Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
        by CrewmanRedShirt
        Hello all,
        As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
        07-13-2024, 11:02 AM
