just picked this up, when turned on go's red to green then to 5 blinks red,does not respond to remote so power board or main, have read 5 blinks could be loss of 5v to main,If i disconnect Y+Z Sus boards still have the 5 blink code,any help gladly received.
panasonic TX-P42S10B 5 blinks
Re: panasonic TX-P42S10B 5 blinks
Follow this guide.
http://www.toms-service-manuals.com/...&Search=Submit
(Different model, 2008 vs 2009, but 5 blinks diagnosis still applies.)
5 blinks can also be plasma panel fault. (Not repairable.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Different model, 2008 vs 2009, but 5 blinks diagnosis still applies.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Looks like it fell at the first fence, checked for the 5v on pin 5 plug P25 and when you switch on it jumps to 4.99v then drops away as the fault code starts to blink,so looks like a D board fault,I will try and see if i can find any thing shorted when i take out the board,Any one found any common faults with these Av boards, i had a 42G20 for parts two weeks ago and the first board to sell was the D and that went after just one dayComment
After a bit more checking and before i get a replacement D board, when i power it up i get 4.99v on pin 5 of p25 on the power board that drops of as the 5 code starts on checking for shorts on this pin there is no short, but if i unplug the y or the z board's from the power board i then get a 7 blink code.this must be telling me something but what?Comment
6, 7, or 8 blinks is expected if SC or SS are unplugged, it is due to the new design Panasonic use in 2008 onwards which detects if boards are removed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Check PANEL MAIN ON, TV POWER ON on PSU schematic, I have a G10B schematic which is same TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Thanks again Tom Just checked main panel on P25 Pin11 shows no change on power on .002v, !5v comes up but falls back as does Vs when 5 code starts, standby is good to, so look's more and more like the main Av don't you think.Comment
Fitted replacement Av and the blink code is now three was five, still not responding to remote, manual say's 3.3v fault replace D board,i am at a loss as to what's next can i power this up by jumping the power board any help gladly received.Comment
42S1 should be close in this.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for the link, i had a 5 blink code that checked out as faulty A board, so today a replacement board was fitted this one is now giving 3 blinks so is also faulty, have contacted the seller and another board is being sent out so will hang in there till that arrives,my thinking now is there can only be a problem with the Av just need to get a working board to put this right.Comment
replacement number two fitted now back to 5 blinks, So maybe the A board is not the problem?, i have noted that with the sc board connected i get a fizzing sound from the power board (i think the relays)and disconnected no sound, but with this set as Tom has said you get a blink code when the board is disconnected not like the old one's if the board was faulty it would power on and come out of standby.Comment
Yes Sc 2 is shorted. have you worked much on these boards this is a TNPA4829 AD looks to be showing some heat around the heatsinks but no burnt out parts that i can see,will check to see if any parts commonly fail before i start pulling it all apart.Comment
No, but I'm thinking it's a false SOS5. So if we went back to the beginning and connected all the boards and you follow this from the guide, You already had 5V until shutdown? yes?
"Find out if pins 1 or 2 of connector P35 are shorted to ground. If shorted, possibly the panel is bad. If there is no short circuit, proceed to check the P5V line.?............
........... measure resistance between pin 5 of connector P25 and ground (Chassis). If P5V is shorted, find out if it’s created on the P board or if it’s created on any of the other boards that the 5V volt is connected to."
I've rebuilt a SC TNPA5081 from the next gen FHD.
You've found no short on the P5V at SC20, I'd check the P15v resistance. Then bell out the IGBTs for any shorted.Last edited by tw2005; 06-07-2013, 08:20 AM.Comment
...1 Photo11-20-2024, 08:52 PM -
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
Hello all,
As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere... - Loading...
