magnavox rear projection tv
  • sisson2004
    • Dec 2006
    how do i determine what bulbs i need the one blue bulb has a few burn marks on it and i can not figure out where to find the bulbs at? any suggestions it is a FP4630 W102 tv
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: magnavox rear projection tv
    they are not bulbs.
    you have 3 crt's
    often what looks like a burn is crap growing in the coolant.
    if you really have phosphor burns you need to find the cause or you will flush whatever you paid for the tubes.
    • sisson2004
      • Dec 2006
      how hard would it be for me to determine what i need to do in order to fix the problem i am really good with electronics just never worked with tv its all been car audio and house hold wiring......any suggetsions?
      • waigy
        Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
        by waigy
        As the title.
        I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
        It looks basic enough inside with large components so I could do a full recap pretty easily.
        Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
        If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
        I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
        11-08-2024, 03:53 AM
      • tonybig10
        Magnavox MDR515H/F7 And Magnavox MDR537H/F7
        by tonybig10
        Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
        the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
        03-07-2025, 01:03 PM
      • howardc64
        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
        by howardc64
        TV was fixed just after removing Samsung's rear snap cover.
        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
        Maybe PSU->backlight connector didn't have a good contact?...
        07-23-2025, 12:34 AM
      • Steven Pieter
        Ipad 9th Both Rear And Front Camera Problem
        by Steven Pieter
        Hello everyone, may I ask a question? I have an iPad 9th generation A1202 with the problem that both the front and rear cameras are not working. However, when checked using 3utools software, the serial number is N/A but the score is 100. I am having a bit of trouble fixing my iPad due to the limited schematic and boardview files. Could someone please help me fix this problem?
        09-23-2025, 09:07 AM
      • AJ847.63e
        8th gen 13" HP Spectre X360 - Is there a MODS like utility to determine which chip is faulty?
        by AJ847.63e
        Hi All,
        We've got a 8th gen 13" Spectre X360 which seems to have faulty onboard memory. Windows was bluescreening with Memory_management errors. Running HPs built in memory test brings up memory errors, but it does not tell you which chip. Is there a MODS like program so you can determine this? Memory is on board unfortunately and don't really want to go order 8 chips and replace all 8 if I don't have to.
        Lastly do you have to use the exact same chips, or can you use chips with the same specs but from other manufactures?
        Thanks for your assistance....
        04-09-2024, 11:42 PM
