pdp60wxdp3
  • neonlight
    • Mar 2011
    pdp60wxdp3
    pdp60wxdp3
    z-board 60hd3
    found 4 diodes shorted beteewn the imps
    020
    021
    022
    023
    changed them now iv got
    +5v 4.74v
    +15 15.37v an fluctuating to 15.59 v
    ipm temps, 20 mins heat run 37/42/55
    any ideas why the +15v is spiking would be greatly appreciated
    Re: pdp60wxdp3
    Bad cap near IPM? May not be a defect - is there an actual fault?
    +5V at 4.74V for me would be more of a concern.
    • neonlight
      • Mar 2011
      Re: pdp60wxdp3
      it was displaying split picture with lots of colered lines.then a short with probe sent the pic dim that blew diodes theres a ribbon cable missing from control /b 2 y board just tested +5v of the main power/board 4.74
        Re: pdp60wxdp3
        Weird lines etc not Y-sus. Control board or main board fault likely. Both sus are only responsible for making the screen light up, more or less.
        • neonlight
          • Mar 2011
          Re: pdp60wxdp3
          iil have 2 get a ribbon cable an see tho what its doing an take it from there.would be nice 2 get this one working
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • Fontana
            BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
            by Fontana
            1. gยดday! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
            2. if
            12-18-2023, 05:45 AM
          • Nikolai Danylchyk
            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
            by Nikolai Danylchyk
            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
            Thanks in advance!...
            05-08-2025, 06:18 AM
          • DjKrish
            Zener diodes component equivalents
            by DjKrish
            Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
            1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
            2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
            3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
            These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
            08-15-2021, 11:06 PM
          • madyoyo
            Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
            by madyoyo
            Hi
            I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
            Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
            12-01-2023, 09:28 AM
