Toshiba 42hp95 Plasma TV has moving vertical Black lines
  • capri013
    • Apr 2013
    hi i have a toshiba 42hp95 with black lines vertical they are not stationary it keeps moving depends on the channels i change i have uploaded 2 video on youtube to view tv issues please any help will do thank you update i have removed one of the ribbons from the buffer boards and now there is discoloration in the right hand upper corner aswell please help me http://www.youtube.com/watch?v=WGFjFKew6Z4
    http://www.youtube.com/watch?v=y0A2tBfa0RQ
  • tw2005
    • Oct 2011
    • 6458
    Re: Toshiba 42hp95 Plasma TV has moving vertical Black lines
    It's not the panel. Panasonic panel and drive boards by the looks of it. The fact it keeps moving and is replicated on in the PIP you had suggests it all in the video processing.
    If it only happens with the Tuner, I'm thinking main board or maybe logic board.
    If you blow those ICs embedded on those top and bottom boards then your TV panel will be junked.
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • pni
      LG 49uf695v vertical coloured lines
      by pni
      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
      11-14-2025, 03:15 AM
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      Sadly it has vertical lines at the left and one line in the middle-right.
      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
      I have factory resetted the TV as well but also with no luck.
      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
      09-06-2024, 05:27 AM
