Philips 50FP5532D plasma Ysus fault
  • alanos313
    • Jan 2012
    • 10
    I have recently been trying to save a Philips 50inch plasma TV with a faulty Ysus and lower buffer board. I have found and replaced two faulty MOSFET transistors on the Ysus board, and bought a replacement (second-hand) buffer.
    On fitting the parts and powering up, the TV worked perfectly. For about 3 hours. Then the picture went fuzzy, with some ghosting and sparkling, interspersed with very bright flickering of the picture.
    I turned the TV off and allowed it to cool for about 30 mins. When I turned it on, it was OK again until it warmed up, when the same problem returned.
    I checked the voltages on the power board (VS and VA) and made sure they were correct. The TV continued to show the fault for around an hour. Then suddenly the picture returned to perfect clarity. It stayed perfect for around an hour, then with an audible 'pop' the picture disappeared completely. Sound continued. I switched off and left overnight.
    Upon inspection, i found a blown IC on the lower Y buffer. I removed the buffer, and swapped over the blown IC with a good one from the old buffer. I also checked the Ysus board, and was surprised to find all the MOSFETs to be ok. So i fitted the repaired buffer, and switched on. Again the picture was perfect for a couple of hours. Then the same fault occurred, although as of yet it has not blown the IC. I have now switched off, and decided to ask on here what I should do next? My inclination is to fit a complete Ysus repair kit even though the components all seem ok when tested with my multimeter. I cannot see any signs of bulging on any of the caps on the Ysus board.
    My question is, What could be causing the fault to occur when the boards get hot? Is there a particular component I should be looking to replace? Has anyone else had this same fault before?
    The Ysus part number is LJ41-05120A.
    The buffers are LJ41-05121A (UPPER) and LJ41-05122A (LOWER)
    Thanks in advance for your thoughts
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Philips 50FP5532D plasma Ysus fault
    Double checked that all connectors are put in place nicely?
    Muh-soggy-knee
    • alanos313
      • Jan 2012
      • 10
      Yes, checked and re-checked. Ordered a Ysus repair kit from eBay for £25. I am thinking maybe one of the FETs is screwing up when hot. The kit also has a few caps and resistors etc in it, i hope once i change them all it will work properly! Just an odd fault, most times things improve as the set warms up... mine seems to be the opposite! I have found a few slightly bulged caps on the power board, however the voltages seem ok even when the TV is hot...
      • cadiman
        • Mar 2010
        • 397
        Used buffer or buffer ics are a really bad idea here.
        The problem is you had a good y board and ruined it with used faulty buffers.
        You do not want to put used buffers in any tv mostly if they didn`t come out of one of your tvs.
        If you buy used buffers and they don`t work you can send them back. The problem is are they going to repair your y board for you that their bad buffer board ruined?
        The easy answer is, no.
        Also, rebuilt buffers are a bad idea too since these companies only replace the faulty buffer and not all of them on each board.
        You need to find companies that will replace all buffer ics on both boards to have the proper repair then mate them with a for sure known good y board. That is why these are mostly sold in a set of three with a warranty too.
        The mosfets are most of the problem but there are other components that can fail.
        The kit you are buying should give you all the items needed to repair a y board that failed due to a shorted buffer.
        • alanos313
          • Jan 2012
          • 10
          Ok so here is an update...
          I have now fitted the Ysus repair kit. Also have a new lower buffer. When I switch the TV on, the screen is black. If i remove the lower buffer and power on, the top half is displayed, albeit with some sparkles. With the lower buffer connected, there is no picture! Both buffers are clearly ok, so can anyone tell me which component on the Ysus board is likely to be causing this symptom? Or could it be a case of adjusting the pots on the Ysus board? I have already checked voltages from the power board and they are spot on!
          • Yanleb
            Schematic or datasheet for Plasma TV buffer chip
            by Yanleb
            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
            05-18-2022, 01:36 PM
          • celiabrown
            Issue with Plasma Philips 37inch chassis FTL2.1
            by celiabrown
            Hello guys,
            My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
            Can someone has any symptom like this ?
            Thanks​
            05-09-2024, 10:56 PM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • alltvrepairs
            Philips 50PUS8555/12 Power supply fault
            by alltvrepairs
            715ga018-p01-006-003s
            Am trying to find a pdf .
            i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
            tried with meter most components like resistors diodes etc.
            in secondary there are no shorts either.
            This was struck by a lightning and could see a burn under the air gap capacitor.
            Attaching the board.
            Any clues welcome.
            Tks...
            08-30-2025, 08:42 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
