Intermitting on/off cycle, Plug in power cord and green On light comes on without a command and flashes for a few seconds and then goes off and the red stand-by light comes on for a few seconds, then the whole cycle repeats again. Cannot turn off unit during this time, it will turn off automatic in 5 min or so. There is no picture during this time. If I keep trying to get it to work, I may after awhile get a picture and sound which are good. When it is working ok, I read several voltages and they seem to be good. maybe it is getting a false on/off control voltage at power up ? I have no schematics for this tv, but do know how to do repair work.
Magnavox 32MD350B/F7 On/Off cycling
by high-techHello everybody, I could use some help on this one... It's got me guessing...
I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
(B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
(B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
(OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
(OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
9. ground (PWM2) 10. 0.9 volts cycling... -
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by tonybig10Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...-
Channel: Schematics and Boardviews
03-07-2025, 01:03 PM -
by nono34Hello,
I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to... - Loading...
