Any ideas? It turns on and works fine, just looks like this. I left it on for an hour to see if it would go away but it didn't :'(
Weird display - Samsung 52"
Any ideas? It turns on and works fine, just looks like this. I left it on for an hour to see if it would go away but it didn't :'(Tags: None -
Re: Weird display - Samsung 52"
Model number? An LCD?
Looks like T-con fault to me.
Have you tried test patterns?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
So was it working then just came on like that?
Have you seen it working properly- has it been moved recently?
Have you checked it with different sourcesPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
It's the LN52A750R1FXZA and is an LCD. What test patterns are you talking about?Comment
Yeah, I've tried a all the hdmi ports and the vga. I haven't seen it work properly but it was free so I figured it's worth sinking a little cash into it if I must.Comment
Access the service menu:
Turn TV into standby, press mute, 1, 8, 2, then power.
After a short time, service menu should appear. I think test patterns are under the CONTROL menu.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
EDIT: Standby is when you power off but it's still plugged in right?Last edited by Jordanqkoch; 04-11-2013, 07:04 PM.Comment
I don't mean that it displays how it should, I mean that it does display lines or just plain white, and is clear.Comment
It will go all white if you move the leads and cut the power on the tcon.
Its too early to tell if the panel is bad.
Did you have a known source connected when testingPlease upload pictures using attachment function when ask for help on the repair
No, I just had the menu open so I had some sort of picture to see how It displayed. Should I try with a source?Comment
Hooked up my computer as a source and played a movie through xbmc, and here are pictures of the results. Messing with the tcon ribbons didn't help. Played back fine (not sluggish) and no ghosting, just these weird discolorations.
If you look closely, the square discolorations are in the same place as my original picture, and always stay in the same place, which makes me think it's the panel :/
No idea mate - does it stay like that if you leave it on a couple of hours?
Looks like Tom is away - bump it again when you see him on other threadsPlease upload pictures using attachment function when ask for help on the repair
Here are some other methods to try and get to the service menu
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.Please upload pictures using attachment function when ask for help on the repair
I haven't tried for a few hours. Maybe about a half hour. I'll leave it on overnight tonight.Comment
Method 1
Method 2
Method 3
Method 4
Method 5
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.Comment
Left the TV on for a few hours and the display looks really dim and white. Here are some pics. You can still see what's going on very faintly.
You probably have bad tab bonds if the problem goes away after some time, though there is a chance of it being t-con/main board, we need to rule those out, to do so I recommend you get a hairdryer or heat gun and heat up parts of the boards one at a time until it works.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Aspire Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) boardview and Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) schematic....09-07-2024, 01:00 AM
- Loading...
