LG 42LG50FD-AD Intermittent NoGo
    Re: LG 42LG50FD-AD Intermittent NoGo
    Well all seems good. The tv has been testing for a couple of days now and is yet to falter again. Thanks to everyone who offered help.
    Cheers
    Con
      Same problem with this set.
      I have 1x 5v voltage, no ps-on voltage tv came cold to me.
      they had it working for 5 days and it failed.
        Recapped the entire board.
        I have voltages there now.
        NC | 0
        PWM-DIM | 1.361V
        ON / OFF | 2.972V
        PS-on | 3.182v added for budm
        ACD | 0
        grd
        grd
        5v | 5.150v
        5v | 5.150v
        grd
        12v | 0
        grd
        16v - 5v | 0
        I am not getting inverter power at all, there is no 24v at the power inverter fuse.
          Where is the Voltage reading of the Power_On (PS-ON signal from main board) pin to turn the rest of the power supply? Still 0V?
            There is no pin connector for ps-on on this board not that I can find anyway.
              Just looked at schematic should of known it wasn't labelled on the board.
              PS-on | 3.182v
                Just made sure all caps where put in their right destinations.
                This has me stumped I am not sure where to go from here.
                  with the inverter plugged pulled the PS-on reads 5.0v is this normal?
                    NC | 0
                    PWM-DIM | 1.361V
                    ON / OFF | 2.972V
                    ACD | 0
                    grd
                    grd
                    5v | 5.150v
                    5v | 5.150v
                    grd
                    12v | 0
                    grd
                    16v - 5v | 0
                    So based on your readings, you have PS-ON but you still do not have the 12V, 16V, or 24v.
                    We need to find out if you do have PFC Boosted Voltage of around 380VDC between the two legs of the main filter cap or not, if you do then we need to find out if that boosted Voltage gets all the way to the rest of the SMPS power supply to produce the 12V, 16V, and 24V circuit or not. We need to have the correct main power supply Voltage first.
                    BTW, that ACD (that AC Detect) signal is 0 VDC, I expect it to be >2V for normal working but I am not sure if 0VDC = NORMAL or >2VDC = Normal.
                      what is the psu board number
                        Budm can correct me. ACD 0 usually needs voltage on that pin or won't start up. NVM
                          I believe the ACD is part of the protection circuit that will stop the power supply from coming on if the incoming AC is not in the operating range. In SONY TV, the ACD (AC OK) = > 2V = GOOD, I do not know if LG uses active low or active high. That signal is sent to the main board and usually will shut down the PS-ON signal, but in this case the PS-ON is present. The topology may not be the same as SONY but I cannot verify 100% since we do not have the diagram of the power supply board.
                          So at this point he needs to at least verify that the PFC is working or not which is easy enough to check.
                            Main filter cap reads 326.1v - 328.3v
                            I suspect the PFC boosted voltage is not up to its correct running voltage.
                            I soldered some wires to main filter cap + - and alligator clipped them as I thought it was safer, hope I have done this right.
                            Vinceroger69 the PSU board is a Eax40157601/17
                              did another test on the Main filter Cap just to be sure.
                              Its reading 322.6v pretty sure its reading low just reading some other threads similar to get a grasp on what might be happening.
                                This may be the diagram for this board:-
                                https://electronicshelponline.blogsp...?view=snapshot
                                  That's the diagram I used to make sure I hadn't used the wrong caps. I was eventually going to link us there.
                                  Text isn't all that great when zoomed in but its a good reference.
                                    So the PFC Voltage booster is not working.
                                    1) It can be due to bad PFC diodes
                                    2) No VCC present to run the PFC IC
                                    3) Failed PFC IC.
                                      have you got a picture of the bottom of the psu pcb maybe then we can help you locate the pfc ic so that you can check all the voltages etc
                                        Is it safe to test the VCC line off that chip soldering a wire to the positive side of C508 and using the chassis as ground. as VCC line of that chip goes straight to the C508 + and D508. stop me if I am wrong I will not move ahead until I have confirmation.
                                        I checked the diodes on the PFC circuit pulled out D508 as he was reading both ways in circuit tested fine out of circuit.
                                        I am using that schematic its been handy so far.
                                          You will be making Voltage measurement in the hot deadly side of the circuit. The GND ref for the hot side is the negative leg of the main filter, not the chassis.
                                          You should at least plug the TV into the GFCI out at the minimum to protect yourself.
