Onn 15" lcd
    Onn 15" lcd
    A friend at work heard I repaired TVs so he brought this small one in for me to have a look at. Normally wouldn't bother but I thought there was nothing to lose.
    Fault: Not powering up. Standby red, pressing the button makes it flicker but it stays on red. Doesn't power up.
    Diagnosis: The 2.5V TS1117 regulator had failed. Before pressing the button, it measured 2.5V, but when pressing the power button it dropped to 2.33V. The TAB pin and 2nd pin of the IC was visibly discoloured -- a deep grey/blue compared to the outer two pins which indicated to me the device must have been badly stressed. In addition, a 470uF 25V capacitor near the LVDS output was bad (bulged), although it wasn't the cause of the fault.
    Fix: The TS1117 was replaced. TV works fine now. The capacitor was later replaced for reliability.
    This emphasises the need to test regulators while the unit is under load i.e. the fault must be occurring. It can't just be in standby.
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • cheeky2
    LG 42LG3000 Strange fault will not go into standby!
    by cheeky2
    I have this LG 42LG3000 Tv which operates on all inputs without any issues whatsoever. However when you try to turn the Tv off the screen goes blank as it would normally however it then turns itself back on again!
    So far I have replaced the main board without any resolution to the problem.
    When the inverters master and slave VIT71053.54 VIT71053.55 are disconnected from the power supply then the TV will turn off as it should (obviously without any ccfl output).
    I have read through a few posts for this model without anyone having this issue as far as I can tell.
    I...
    05-04-2021, 06:02 AM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Rictech
    Panasonic SA-MAX770PU SMPSU board fault....
    by Rictech
    Hello everyone. 😀
    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
    There are no devices that have exploded or otherwise show signs...
    08-26-2024, 01:05 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
