RCA 42PA30RQ Clicking Relays
  • RedeyeJay
    Hobby RepairDIY
    • Mar 2013
    • 24
    ok so i got this TV from a customer of mine when delievering his new couches
    im some what savy as far as electronics go but this is my first REPAIR on a LCD tv
    I ordered a new power supply from Shopjimmy.com
    Didnt fix the problem. when i disconnect the X-Y main board it doesnt continuously click like it will when its all hooked up , and i have no backlighting no picture , havnt hooked it up to anything yet as far as computer to see if im getting sound or not ,
    reply to this thread if u think u might beable to help me out here id really love to have this TV fixed for under 100 $ total would be a nice gift for my wife since all we currently have is a 32" vizio which is a great TV set i must admit 3 + years now of constant use and no issues ever !
    Re: RCA 42PA30RQ Clicking Relays
    Well, a good start would be to note this is a plasma, not an LCD. It does not use a backlight.
    If it stops clicking when X-main disconnected, the X-main is bad and should be replaced.
    If it stops clicking when Y-main disconnected, the Y-main is bad and should be replaced.
    • RedeyeJay
      Hobby RepairDIY
      • Mar 2013
      • 24
      its the setup were the X board is driven with power from Y board , i looked at several of ur trouble shooting tips i tested buffers for shorts with my Analog meter and the ohm resistance was the same on all pins from Y board pins to buffer board , im stumped atm with why its shorting out i read the entire thread with u and Bling
      i appreciate any more help u have for me as im 50 $ into this set already and want to keep costs under 100 $ if at all possible
      • RedeyeJay
        Hobby RepairDIY
        • Mar 2013
        • 24
        when the main power for Y board is diconnected it doesnt click like it does with it connected , ive tested alot of the little blue caps for ohms i believe its a "Good" reading , but like i said im kinda a newbie at this , im great with building computers and software , hardware troubleshooting is new to me entirely
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Cant test caps effectively with old-fashioned analoge meter. You need an ESR meter for caps or substitution.
          So--dis the X board from the Y and try again--Does it still trip (click)?
          TELEFIX
          • RedeyeJay
            Hobby RepairDIY
            • Mar 2013
            • 24
            ya it still clicks with X board disconnected
            • RedeyeJay
              Hobby RepairDIY
              • Mar 2013
              • 24
              and the meter im using is a M1015b commercial
              • RedeyeJay
                Hobby RepairDIY
                • Mar 2013
                • 24
                should i order the Y Main board , and if so what website do u trust ? i used SJ.com for the power board , they seem to have a full menu of all the parts for this model and decent prices also i must add ... 22 $ for Y main board
                  You will need to remove the Y-buffer completely to test it.
                  https://www.youtube.com/watch?v=51SZsfH60EY
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Diagnosis indicates fault is on YSUS.
                    That analogue meter is Not suitable for testing caps nor is it accurate enough to set the rail voltages in Plasma sets.
                    TELEFIX
                    • RedeyeJay
                      Hobby RepairDIY
                      • Mar 2013
                      • 24
                      Ok I went and got a digital meter it's not the fancyest but igot a manual for this as I didn't for analog what setting should I use to test the y buffer boards pins ?
                      • RedeyeJay
                        Hobby RepairDIY
                        • Mar 2013
                        • 24
                        Cen tech model 92020 is the meter was 5$ on sale lol
                          Does your meter have an audible continuity mode?
                          If not, you will need to set it to 200 ohm and run it slowly along each pin (one per second) checking for any reading other than the normal "1".
                          If it does have the audible mode, you can use that to hear a beep when a short is encountered, which allows you to more easily find a fault.
                          • RedeyeJay
                            Hobby RepairDIY
                            • Mar 2013
                            • 24
                            O and I checked the old power supply the tv had same thing only got the 1 set of click to turn on so I'm going to send back the other 55$ power supply gotta pay a 20% restock fee but if I can just use the rest of the money to buy what I actually need I think ill still win , and I also read ur post about plasmas and how they work is it easy to spot cracks ?
                            • RedeyeJay
                              Hobby RepairDIY
                              • Mar 2013
                              • 24
                              No it doesn't that one was like 20$ I should've gotten that but bills came up lol
                              • RedeyeJay
                                Hobby RepairDIY
                                • Mar 2013
                                • 24
                                What's the easiest way to seperate the white connectors from buffer to y board ?
                                  You pull on them. Sometimes the Y-board has to come out.
                                  • RedeyeJay
                                    Hobby RepairDIY
                                    • Mar 2013
                                    • 24
                                    Pulling won't damage it ?
                                      Be careful, but no, it shouldn't damage it.
                                      The panel connectors (orange) are the ones to be careful about.
                                      • RedeyeJay
                                        Hobby RepairDIY
                                        • Mar 2013
                                        • 24
                                        Ok here goes nothing crossing toes n fingers
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • mikelu53
                                          Samsung UN60D8000YF Clicking BN44-0432A
                                          by mikelu53
                                          I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                                          The set was working then not,then started clicking.
                                          Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                                          Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                                          A schematic or suggestion would be great.
                                          01-21-2023, 03:14 PM
