Sanyo DP50749 Plasma No picture
  • Jumpa
    • Nov 2015
    • 15
    Re: Sanyo DP50749 Plasma No picture
    will the numbers off of it help at all ?
    • Jumpa
      • Nov 2015
      • 15
      one inch three sixteenths wide 1"3/16"
      one inch nine sixteenths long 1"9/16
      my wife is gonna have to count them when she gets home
      • Jumpa
        • Nov 2015
        • 15
        I counted 56
        • Jumpa
          • Nov 2015
          • 15
          56 pins I counted on one side
          • Jumpa
            • Nov 2015
            • 15
            • Jumpa
              • Nov 2015
              • 15
              much better picture
              • Jumpa
                • Nov 2015
                • 15
                Originally posted by freakaftr8
                Yes if that ribbon cable is damaged it all you will have a area in the picture that will have vertical multicolored lines or no picture at all is that looks like it carries the information for the vertical drivers on the panel.
                That's most likely your problem. Now I believe that panel is manufactured by Panasonic if I'm not mistaken.
                You are correct sir it has Panisonic stickers all on the inside of it !!
                My wife asked me "why does a Sanyo TV have Panisonic parts inside"? I said honey it is just like politics dear..& how the Republicans & Democrats want everyone to think they are completely different entities, yet on the inside & behind closed doors they are all the same , they are all in bed together.
                Thanks for the reply
                • Jumpa
                  • Nov 2015
                  • 15
                  Agreed. The chip on film technology incorporated into plasmas for the vertical gate drivers are very finicky and you could easily short them out
                  Did you get the message I sent you ? with the picture of the ribbon ?
                  You were right when you said it will be hard to find
                  55 pin 1.316". x 1.516"
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Here's the one I have. Hope it could work
                    • Jumpa
                      • Nov 2015
                      • 15
                      Wow thanks man, but i don't think it will bro I stopped counting at 65 pins and still had a ¼ of it to go.
                      Thanks for the valiant effort my friend!
                      Greatly appreciated
                      ~Rick
                      • tw2005
                        • Oct 2011
                        • 6458
                        For future ref, the easy way to find out how many pins is look at the connector as the first and last pins are often labelled. So an inspection of the C boards shows 55.
                        Also, find the board number then drop the suffix, search that and you find TH-50PH12U uses the same c boards.
                        You now have an alternate path with which to find that ribbon.
                        you then search a manual
                        Identify the connectors, you find c22-c32.
                        you search C22 or C32 in the parts list
                        you find CABLE (C22-C32) = TSXL737
                        you go to Encompass https://www.encompassparts.com and enter that part number
                        you find
                        In stock for $4.68
                        You also discover it's used in all these, more opportunities LOL
                        Manufacturer Model Number Description
                        Panasonic TCP42X1 42" PLASMA TV
                        Panasonic TC58PS24 58" PLASMA TV
                        Panasonic TCP58VT25 58" PLASMA 3D TV
                        Panasonic TCP58S2 58" PLASMA TV
                        Panasonic TC65PS24 65" PLASMA TV
                        Panasonic TCP65VT25 65" PLASMA 3D TV
                        Panasonic TCP65S2 65" PLASMA TV
                        Panasonic TH103PB1 103" PLASMA TV
                        Panasonic TC54PS14 54" PLASMA TV
                        Panasonic TC50PX14N 50" PLASMA TV
                        Panasonic TC58PS14 58" PLASMA TV
                        Panasonic TCP58S1 58" PLASMA TV
                        Panasonic TCP50C1 50" PLASMA TV
                        Panasonic TCP54G10 54" PLASMA TV
                        Panasonic TCP54V10 54" PLASMA TV
                        Panasonic TCP58V10 58" PLASMA TV
                        Panasonic TCP65V10 65" PLASMA TV
                        Panasonic TCP54S1 54" PLASMA TV
                        Panasonic TC65PS14 65" PLASMA TV
                        Panasonic TC42PX14 42" PLASMA TV
                        Panasonic TCP42C1N 42" PLASMA TV
                        Panasonic TCP54Z1 54" PLASMA TV
                        Panasonic TCP50C1N 50" PLASMA TV
                        Panasonic TCP65S1 65" PLASMA TV
                        Panasonic TCP42C1 42" PLASMA TV
                        Panasonic TCP50X1 50" PLASMA TV
                        Panasonic TCP42X1N 42" PLASMA TV
                        Panasonic TCP50X1N 50" PLASMA TV
                        Panasonic TC42PX14N 42" PLASMA TV
                        Panasonic TC50PX14 50" PLASMA TV
                        Panasonic TH103PF12U 103-INCH 1080P HD PLASMA PROFESSIONAL DISPLAY
                        • tw2005
                          • Oct 2011
                          • 6458
                          80 pin
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Crap! I'm sorry. Think I grabbed the wrong one. I'll look again
                            • adavila8908
                              • Dec 2015
                              • us
                              #34
                              where can I find a panel for this exact tv
                              • adavila8908
                                • Dec 2015
                                • us
                                #35
                                can display panel ribbon be replaced on sanyo dp50749
                                • Yanleb
                                  Schematic or datasheet for Plasma TV buffer chip
                                  by Yanleb
                                  I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                  So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                  Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                  05-18-2022, 01:36 PM
                                • howardc64
                                  by howardc64
                                  07-24-2025, 05:17 PM
                                • KYBOSH
                                  Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                  by KYBOSH
                                  Saved this beast from the landfill this weekend.
                                  Manfactured July 2013 in Mexico.
                                  I love working on plasma TVs.
                                  Its been a while but I was lucky enough to find 2 this week.
                                  The TV powers on and stays on but no picture. Havent checked for sound yet.
                                  No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                  Will start troubleshooting tonight.
                                  10-17-2024, 01:17 PM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
