Magnavox DTV converter won't stay on
  • MagnumOpus
    • Mar 2013
    • 13
    Hi all:
    DTV converter is a Magnavox TB100MW9, manufactured by Funai.
    It got very light use for about two years, and then it started powering off by itself.
    This appears to be a common problem, as I've seen posts in other forums, but no solutions offered.
    Typically, one would first suspect the power supply, but there is none.
    110v leads are soldered directly to the board.
    I visually examined all caps; there are no apparent signs of failure.
    So my question is:
    Has anyone else encountered this problem, and if so, are there any solutions?
    Thanks.
    Re: Magnavox DTV converter won't stay on
    There IS a power supply. It will just be integrated onto the main board in some way.
    • MagnumOpus
      • Mar 2013
      • 13
      Re: Magnavox(Funai) DTV converter won't stay on
      OK, thanks; I see what you mean.
      Part of the board is labeled "HOT" and contains (among other things) a 200v cap and what appears to be a transformer.
      I also need to clarify my initial post:
      It shuts down to standby mode, not completely.
      The power switch needs to be turned off for complete shutdown.
      Next question(s):
      Is there any specific component on the board that's most likely to cause this shutdown problem, and is it necessarily limited to the "HOT" side?
        Can we see some pictures first?
        • MagnumOpus
          • Mar 2013
          • 13
          OK, this is the closest I can get without losing focus.
          • MagnumOpus
            • Mar 2013
            • 13
            Also, the brown substance next to that cap doesn't appear to be from it.
            (It's actually next to it.)
            I noticed that right away, the first time I opened the unit.
            I believe it's some sort of glue or sealer.
            • bluto
              • Oct 2007
              • 560
              Take a good look at all the components and look for anything that looks like it got hot or looks slightly burnt. Look at the tops of all of the capacitors for any signs of bulging or leakage at the bottom. You might also look on the opposite side of the board for bad solder joints. If everything looks good, I would probably start to check for bad caps. If you don't have a capacitor checker, then you may just have to shotgun replacements. The 7 caps around the yellow transformer are for the secondary side of the power supply and would be likely suspects. If you are going to replace them, I would also probably bump up the value of the primary filter cap (the one with the white sealer goo) slightly.
                Wow, that's cheap. It's got a self-oscillating power supply. WHY do Funai (make lower end Magnavox stuff) insist on still using these, I do not know.
                There are some voltage check points like AL-3.3V, have tested these?
                • MagnumOpus
                  • Mar 2013
                  • 13
                  I did that before starting this thread, but went back to double-check and verify that I didn't miss anything.
                  Everything appears OK. I even desoldered the cap next to that aforementioned brown goo to verify that it wasn't coming from that cap; it's not.
                  Shotgunning replacements would be my only option as I don't have a capacitor checker.
                  At one point, I could have, but no longer. Things have gotten worse; now the box powers off to standby immediately, so there's no time to check.
                  Would it be possible for me to solder the wiring from an AC-to-DC adapter directly into the board, bypassing the power-supply circuit? Or might the transformer have multiple voltage outputs (which would render this idea useless)?
                  Much thanks to both of you!
                    You can still check the voltages in standby.
                    This would probably not work because the power supply has multiple outputs.
                    • MagnumOpus
                      • Mar 2013
                      • 13
                      OK, thanks...here we go:
                      Multitester is analog, so voltage readings are approximate.
                      Markings are in quotes, next to jumper numbers.
                      These are the only ones that show voltage:
                      J602 7v "VT"
                      J612 7v "VT"
                      J621 .5v "SAFTY" (mispelled, I suspect)
                      J622 1.65v (under the circuit board)
                      J631 .25v "D-1.8V"
                      J638 3v "VMUTE"
                      J644 .05v
                      J647 3.3v "DTV-S-SIN"
                      J649 3.3v "D-ALL3.3V" (under the sticker)
                      J650 .5v "SAFTY"
                      J651 .05v "9V"
                      J655 2.5v
                      J657 3.3v "D-ALL3.3V"
                      J659 3.3v "D-ALL3.3V"
                      J661 7v
                      • VladC
                        retired EE
                        • Jan 2014
                        • 7
                        So is this thread still alive? I have the same two boards which do not turn on. I can see generation on quarts and voltages look like OP posted. One board is blackened under the D620, but the diode works (other board no visible damage). I hope it does count as my first post. I have some knowledge about electronics and tools and skills but I need help. Please do!
                        • kotel studios
                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                          by kotel studios
                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                          State I got it in:
                          Squealing from the PSU
                          After logo I get a blank screen
                          After 10 seconds of having a blank display w/ backlight the TV dies
                          Give it 7-10ish seconds again and it starts to bootloop.
                          What I did so far:
                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                          Checked all voltage rails:
                          5VSB - 4.8V
                          AMP+13V - 14.4V
                          13V - 12.98V (in manual 12V)...
                          09-21-2025, 02:00 AM
                        • tonybig10
                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                          by tonybig10
                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                          03-07-2025, 01:03 PM
                          MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                          The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                          Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                          10-23-2024, 03:23 AM
                        • gizmo1990
                          What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                          by gizmo1990
                          I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                          The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                          10-21-2024, 08:02 AM
                        • wolf1976
                          i look for equivalent dc to dc converter
                          by wolf1976
                          hi
                          in an inverter of aircondition i have dc to dc converter mes1515mh
                          i have attachment the pdf file
                          can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
                          the problem is instead 15 volt dc output i have only 6,45 volt
                          thanks on advancxe...
                          08-01-2024, 04:52 PM
