Prima PDPPH-4237P Schematic for parts?
  • geb
    • Mar 2013
    Hi -- Anyone know where I can find a parts schematic for the above mentioned or know what the values of these items are, they are located on the power supply.
    D5008 D5028 C5023 C5069 any help would be appreciated.
    tks in advance.
  • geb
    • Mar 2013
    Re: Prima PDPPH-4237P Schematic for parts?
    Well with no help from this forum I managed to get the tv going again, changed a couple diodes and ceramic resistors.
    • Mark D
      Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
      by Mark D
      The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
      10-29-2024, 03:15 PM
    • atunguyd
      Acer x163w Monitor PSU schematic
      by atunguyd
      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
      03-05-2025, 02:08 PM
    • H H
      3090 FE Part Confirm/Identification
      by H H
      I'm hoping someone could help me confirm if I have identified the following parts correctly.
      Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
      The parts needing replacement are on the back of the board behind the HDMI input.
      I have identified the parts as the following:
      C6037: MLCC 0.1uf/16v(0402)x7R W05
      R6016: RES 499 OHM 1/16W (0402) 1%
      LB10911: Ferrite Bead (0402)...
      02-16-2025, 01:09 PM
    • Thetechdude
      MSI Ventus RTX 4080 16G Broadview schematic needed
      by Thetechdude
      Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
      I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
      Thanks.
      07-15-2025, 11:15 AM
    • Adv10119
      Need help please! schematic for LA-9982P rev 3.0 (A02)
      by Adv10119
      Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
      I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
      I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
      01-31-2024, 01:18 AM
