LG model RM-26LZ50 is slightly blurry
  • soldercap
    • Feb 2013
    • 17
    • canada
    Need help trouble shooting. I got this tv from a friend and the picture is distorted just a bit. For instance when showing numbers you can make them out but it is not aligned as they should be.
    So far I have tried another cable outlet and also used a DVD player and got the same results. From what I have briefly read here, it might be the Tcon board, but any other insight would be appreciated
    Re: LG model RM-26LZ50 is slightly blurry
    Can we see a picture of the distortion?
    • soldercap
      • Feb 2013
      • 17
      • canada
      Thanks for the quick reply. I will get it to you later.
      • soldercap
        • Feb 2013
        • 17
        • canada
        Here is a photo of what the picture looks like
          We have seen this before. Often it is due to a failing voltage regulator on the main board, relatively easy to find and replace. Does this TV have any digital inputs e.g. HDMI/DVI. If so is it different on these compared to analog sources?
          • soldercap
            • Feb 2013
            • 17
            • canada
            yes it has a DVI
              So, on DVI, does it look the same, with that noisy/unstable look to it?
              • soldercap
                • Feb 2013
                • 17
                • canada
                I will check. Right now, I do not have a DVI cable to hook up
                  I am going to bed now, but if you post some pictures of the main board after doing the test I describe, I will help with further diagnosis. The main board is the board you are connecting the video inputs into and will be visible upon removing the case. Clear detailed photos are preferred as we don't have the boards in front of us and they are our eyes.
                  • jbfr_54
                    • Dec 2012
                    • 52
                    • France
                    I had two of these sets doing the same thing a few months ago. All voltages were good but on the main board (SSB), the power lines around the video circuit were very noisy (above 100millivolts). This was due to bad electrolityc caps (aluminium surface mounted) that I had to replace by new ones. As I did not have the SMD types, I replaced by conventional ones, there is enough room to put them.
                    I cannot remember which ones I had to substitute but if you have an oscilloscope, check the positive pole of the electrolytic caps that have there negative wire connected to ground (unless they are not filtering caps). The noise over the positive wire should be less than 100mV. If not try to place a capacitor of same value in parallel and watch your image. Warning, do not parallel the cap when the set is powered as you could damage the regulators due to the surge an uncharged cap would produce on the regulator or switching transistor on the line under consideration.
                    I will try to give you a picture of the fixed board and the ID's of the capacitors on the board as I still have one of these sets.
                    Good luck.
                    Jean
                    • soldercap
                      • Feb 2013
                      • 17
                      • canada
                      Thanks for the help, but I do not have the cable to hook up to the dvi, and today it is a holiday so will get it tomorrow
                      • soldercap
                        • Feb 2013
                        • 17
                        • canada
                        I was able to get a dvd player with a HDMI output and used the hdmi to dvi cable to connect to the TV. Picture is perfect!!
                        Do you want the pictures of the main board?
                          Yes, please. This confirms the issue is in the analog processing side and narrows down the fault.
                          • soldercap
                            • Feb 2013
                            • 17
                            • canada
                            Is this picture good enough
                              That's more than good enough. Thanks for supplying a good picture.
                              Read retiredcap's guide on diagnosing faulty regulators:
                              https://www.badcaps.net/forum/showthread.php?t=22231
                              and supply the list in the format suggested.
                              • soldercap
                                • Feb 2013
                                • 17
                                • canada
                                Thanks. It's hard to see the part numbers on the regulators. So I was looking for a parts list fro the board but no luck.
                                What did you mean supply the list in the suggested format?
                                Pin 1
                                Pin 2
                                Pin 3 ?
                                  Suggested format is:-
                                  AS1117-33 -> line 1 of the IC
                                  0506 -> line 2 of the IC
                                  pin 1 = 0.000
                                  pin 2 = 3.301
                                  pin 3 = 5.001
                                  As an example. The readings are taken in volts DC, 20V scale (if not autoranging), with black probe on chassis of TV, red probe on each pin. The larger "tab" pin is physically connected to pin 2; this may be easier to probe than pin 2.
                                  • soldercap
                                    • Feb 2013
                                    • 17
                                    • canada
                                    Good that's is what I thought. Will attempt this in the next hour or so
                                    • soldercap
                                      • Feb 2013
                                      • 17
                                      • canada
                                      Sorry for the delay but unfortunately not all the chips are marked the way you described.
                                      I was able to get hold of a service manual and part list for that circuit board.
                                      It was from LG with the same chasis...ML-041A
                                      I will use the circuit board number and give you the chip number. here is an example
                                      IC2, IC4, IC601 all used 1117A-33CYTR, but on the chip was B533399GC
                                      Pin 1=5v
                                      pin2= 3.2v
                                      pin3= 0v
                                      Will this be ok
                                      After collecting all the data something did jump out at me it was
                                      IC3...very small and numbers on the chip are not readable according to the parts list it is
                                      KIA7027AF3
                                      pin1 = 3.2
                                      pin2 = 0
                                      pin3 = 3.2
                                      but I am not sure what the readings should be
                                      I can give you the rest of the readings if the format is ok with you
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Pin 1=5v
                                        pin2= 3.2v
                                        pin3= 0v
                                        Will this be ok
                                        Unless you have an analog multimeter, report all the digits that the multimeter shows.
                                        --- begin sig file ---
                                        --- end sig file ---
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • edugimeno
                                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                          by edugimeno
                                          Hi!!
                                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                          At a certain point, moving stuff around, I put all wires back in place and...
                                          03-24-2024, 02:31 PM
