LG model RM-26LZ50 is slightly blurry
  • soldercap
    • Feb 2013
    • 17
    • canada
    Re: LG model RM-26LZ50 is slightly blurry
    It is a digital meter here are the readings
    For the 1117A-33CYTR
    IC2
    pin1 = 0
    pin2 = 3.82
    pin3 = 5.04
    IC4
    pin1 = 0
    pin2 = 3.29
    pin3 = 5.08
    IC601
    pin1 = 0
    pin2 = 3.29
    pin3 = 5.1
    For the chip marked IC3 which is KIA7027AF3
    pin1 =3.284
    pin2 = 0
    pin3 = 3.275
    I will update the other regulators in a bit
    Thanks for your patience
      IC2
      pin1 = 0
      pin2 = 3.82
      pin3 = 5.04
      This is probably the faulty device. Though it could also be the nearby electrolytic capacitors.
      • soldercap
        • Feb 2013
        • 17
        • canada
        oops...checked my page where I wrote the readings down and it was
        IC2
        pin2 = 3.282 instead of 3.82
        I will get the others today
        • soldercap
          • Feb 2013
          • 17
          • canada
          here are the rest
          the next set in the manual says LD1086DT18TR
          on the chip says
          1086
          18
          gkdc3453
          Readings:
          IC6
          pin1 = 0
          pin2 = 1.79
          pin2 = 3.281
          IC505
          pin1 = 0
          pin2 = 1.808
          pin3 =3.292
          IC906
          pin1 = 0
          pin2 = 1.796
          pin3 = 3.293
          next set in manual says FAN1587AD33X
          on chip
          DE8AF
          1587AD33
          IC604
          pin1 = 0
          pin2 = 3.291
          pin3 = 5.10
          IC905
          pin1 = 0
          pin2 = 3.292
          pin3 = 5.05
          next
          IC103
          KIA78
          MO8R
          F01
          pin1 = 12.14
          pin2 = 0
          pin3 = 9.02
          IC300
          KIA
          78D09F
          505
          pin1 = 12.14
          pin2 = 0
          pin3 = 9.02
          IC8
          KA78
          O5R
          F03
          pin1 = 8.00
          pin2 = 0
          pin3 = 4.98
          that is all of them
            I'd have a look at this thread.
            https://www.badcaps.net/forum/showthread.php?t=19103
            I'd be thinking of IC500 -- the large analog video processor (it appears to be what processes the analog video into a digital signal for the gm5221, which then sends the signal to the LCD panel.
            • soldercap
              • Feb 2013
              • 17
              • canada
              #26
              That looks a little beyond my capabilities for replacing
                I should be more clear. I think the issue is with IC500, but it's caused by one of the surrounding regulators.
                • soldercap
                  • Feb 2013
                  • 17
                  • canada
                  #28
                  oh I see
                  I am not near the unit today but will investigate. I will try to access the manual online to see which ones control it
                  thanks
                  • soldercap
                    • Feb 2013
                    • 17
                    • canada
                    #29
                    Sorry tom66...I was away for a few days
                    I was wondering ...with IC3, marked KIA7027AF3
                    why are the readings so close?. here they are again
                    pin1 =3.284
                    pin2 = 0
                    pin3 = 3.275
                      Looks to be a "voltage detector" not a voltage regulator, basically makes sure the 3.3V voltage is OK.
                      Do you have / can you borrow a scope?
