Determining TV Model/Versions for Correct Parts
  • randtek
    • Oct 2011
    • 280
    • US
    I have seen many posts over time from people wondering if they can use a board from "X" model TV in their "Y" model TV. I also see posts from people who bought a board on ebay or other sources from the same model TV, and it does not work. I am sure that a lot of these are due to the versioning systems that manufacturers use. Proper checking of versions can greatly reduce your chances of getting the incorrect part.
    Manufacturers often make changes to TVs during production runs. Sometimes to address problems found in earlier versions, sometimes due to changes in part availability or pricing. The bottom line is, You can often open up 2 TVs that are the same model, only to find that they are completely different inside, different boards, panels etc. Most manufacturers will indicate these changes in some fashion, if you know what to look for. Here are some that I am aware of, and I would love to see others chime in with versioning information that they may have on other manufacturers.
    Sony: BEWARE!!! Sony changes versions on TVs often, and the ONLY indication will be in the serial number range. You must consult a cross reference on Sonys to be sure you get the correct parts. On Sony version changes, the parts are almost never interchangeable
    Samsung: There will be a version number, sometimes on the Model/Serial number sticker on the rear, more often on a sticker on the side. The version number in a Samsung is usually four characters, 2 letters and 2 numbers, such as AY01, CN04, etc.
    LG: The version is the full service code for example on Model 47LE5400, one possible service code is 47LE5400-UC.AUSWLHR. All of the Characters after the dash (UC.AUSWLHR) are the version information.
    Panasonic: Can be tricky. May be on a side sticker, may be an extra character on the Model/Serial tag, a few were even indicated by the COLOR of the side sticker.
    General: Often manufacturers of minor brands will have a Rev. (or revision) number listed on the serial number sticker. I have seen some where the version is indicated in the serial number.
    Re: Determining TV Model/Versions for Correct Parts
    I'll add a few of mine:
    Philips: In general, can be swapped, even if the "CTN" (commerical type number e.g. 42PF5521D/05) is different. The option codes e.g. 00320 33022 etc can all be programmed in with the remote if the main board is swapped. Panel versions models etc can be changed as long as that board originally supports the panel required.
    LG Plasma: Two different PSUs used during production run of 42PX5D. One, by Sanken, well made with good caps, rarely fails. Another, by LG themselves, poorly made with poor caps, often fails. They are interchangeable.
    Panasonic Plasma: Suffix of main board sometimes important, sometimes not. (A user on here replaced his main board with one from a model using fans (his TV did not use fans), but we were able to disable the fan detect.) Sustain boards are usually specific to a particular screen size.
    Great guide!
    • Mark D
      Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
      by Mark D
      The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
      10-29-2024, 03:15 PM
    • 2elw
      SVOD4 PCB pictures + parts
      by 2elw
      Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
      STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
      GW1N-UV9UG169C6/I5 FPGA - Its a...
      07-04-2025, 12:23 PM
    • SurrealMustard
      What parts can be salvaged from a plasma with a damaged display panel?
      by SurrealMustard
      I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
      03-09-2025, 08:29 PM
    • DynaxSC
      Asus Rog Strix B360-I Gaming - Parts Identification
      by DynaxSC
      I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
      I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
      Thanks in advance...
      08-23-2023, 07:56 AM
    • lorins_core
      BQ24800 to can it be replaced with these parts BQ24780S
      by lorins_core
      Hello to all.
      may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
      I need some good advice and also some information about it. thank you and God Bless...
      05-10-2024, 07:56 PM
