Panasonic sc tnpa5081 rebuild
  • Alastair E
    replied
    Re: Panasonic sc tnpa5081 rebuild
    check out app-note in my sig. It explains how Plasma sets work.
    All the SC is basically is a 6 legged H-Bridge and some floating-supplies and floating driver LV supplies...
  • peteburns
    replied
    So MID voltage should be 1/2 of the VSUS, roughly +105V, and VAD is roughly -170V, while VFG is virtual floating GND, pulsating between VAD and VSUS? What about the rest?
  • peteburns
    replied
    Hi all, please does anyone have a list of correct voltage values on this board and/or oscillograms at some important points? I fixed some Samsung plasmas but this Panasonic is too chaotical...My power board looks OK, with VSUS being +208V and Va being +60V roughly, +15V and +5V are OK too, but those output voltages from SC board are mystery - VAD, VFG, VSCN, VOL, MID...It would be nice to test all the IGBT and MOSFET control voltages and make sure they are OK before finally powering the board to VSUS :-) Thank you very much for any info ;-)
  • 11alon11@gmail.com
    replied
    Hi I did more work on the TNPA5081 with the 6 blink error and found that the resistant in IC771 center pin to the left is is about 900ohm and in a good board i tested its about 1400ohm any suggestions?
    by the way MID voltage is going up to 100v and then down once it detects the 6 blinks
    replied
    blue capacitors?
  • Hombre
    replied
    Can you check MID voltage, across those blue capacitors, it should be half of VSUS, so somewhere around 100V, if it is lower than that it will trigger 6 blinks, if everything else looks ok.
  • tw2005
    replied
    Originally posted by 11alon11@gmail.com View Post
    this is what was replaced on the TNPA5105 on both after replacing the parts I get 6 blinks and no more blown parts with jumper 50 on
    R 401 & 402
    D451 & 490 & 491 & 618 & 652
    D721
    Q501 & 521 & 551
    Q401 & 402
    IC724
    Q661
    Q601 & 660
    Ic501 & 521
    Q451
    Q421 & 422
    I've done a total of 1 of these. I really should keep a logbook, so hard to figure what I replaced.
    looks like D451, R451, Q451, D482(R553?), Q551,R551, IC521
    Q421, Q422, Q621, D642, Q401,Q402, Q660, Q661, Q701, (Q702?) IC773,
  • tw2005
    replied
    That's certainly a big list for the 5081, I would say absolute worst case scenario. The only snags I remember is missing D451 shorted causing 6 blink, or a defective SOS6 detection cct which is unusual but possible and if the onboard LED ios open cct that too will create a 6 blink.
    I wonder if you put a part in wrong since you've managed to get the same result on 2 boards?
    Interesting to look at that list considering it says it fixes 42C2, 55ST30!, and 54" models which have more transistors
    replied
    I also replaced IC771 on the TNPA5105 with no results and checking resistant on the 15v, 5v and sc2 no short, checking voltage on sc20 I do get 5v and 15v and on sc2 about 200v until the 6 blinks when voltage go down
    replied
    R 401 & 402
    D721
    Q501 & 521 & 551
    Q401 & 402
    IC724
    Q661
    Q601 & 660
    Ic501 & 521
    Q451
    Q421 & 422
    replied
    this is the list of parts replaced on the tnpa5081 rebuild
  • tw2005
    replied
    I have tried to rebuild 2 boards TNPA5105 and TNPA5081for the TNPA5105 I used the shopjimmy kit and for the TNPA5081 i used the Zentronix kit. Both of the board's will power up and not blow anymore parts but I get the 6 blinks on both with the short on the 50 connector. I have checked and rechecked with no success no parts blow any more but I get the 6 blinks I am at a loss can someone try and help me
    Did the kits come with instructions or a parts list and locations? Can you post up images of those lists or compile a list of every part removed and replaced?
    Did you use every part supplied?
    replied
    I have tried to rebuild 2 boards TNPA5105 and TNPA5081 for the TNPA5105 I used the shopjimmy kit and for the TNPA5081 i used the Zentronix kit. Both of the board's will power up and not blow anymore parts but I get the 6 blinks on both with the short on the 50 connector. I have checked and rechecked with no success no parts blow any more but I get the 6 blinks I am at a loss can someone try and help me
    replied
  • tw2005
    replied
    Been busy this week tidying up loose ends on a few boards I had busted but been too lazy to get into it.
    Did another 5081 which I'd started which is not ideal if you don't take notes of what's been done.
    So result of that was it failed, blowing 90% of the bits I'd just done.
    anyway I had forgotten about a couple of resistors that were a bit brown, R421,R422. They were open, so redid the board, replaced those 7.5 ohm gate resistors and this time all good.
    First one of these I've done with those bad.
    Also I subbed RJP56F4A for the DG502 and no dramas there.
  • Stryff
    replied
    I ended up sending my board to PTS, they did an excellent job & I had even removed components before sending it to them... looked factory. Although my board didn't have a burned trace!
  • Tech 57
    replied
    they shipped it today when i get back i will post pictures
    thanks phil
  • tw2005
    replied
    Originally posted by Tech 57 View Post
    Sent a board to PTS they said it had a burnt trace.
    I have repaired boards with burnt traces before.with a wire.
    what is your opinion.I just think they are lazy and don't want to fool with it.
    they are sending it back to me.think i will give it a shot.
    Have you repaired boards with a burnt trace?
    thanks phil
    Damaged , yes but the trace was still there . That was after the thing had gone through 5 or 6 rebuilds to get it going.
    Another I F..ed up and burnt a hole into the board at a smd diode .
    A 4782 board same deal one f the diodes burnt through.
    did they say where or how bad? Send you any pictures?
  • Tech 57
    replied
    thanks phil
  • Neelix
    replied
    I got one of these boards to repair. Going to slowly work through all the pages in this thread. Lots of helpful suggestions on what to check and so on
