So far this forum has been super helpful, thanks to everyone that pitches in for that. I've been working on a Sayno power supply that I've gotten a ton of help with on here.
I was given an LN55C630K1FXZA that wouldn't power up. Was at a home that suffered a bad nearby lightning strike and subsequent power surge. There was a dead fuse on the TV and when that was replaced it came back on no problem. It was then suffering a strobe light flickering issue when it warmed up, but thanks to this forum I found that it's a common issue that just needs a jumper cut for it to go away, and now the final issue...
HDMI inputs do not produce any video or sound. Only the "No/weak signal" message. Component inputs work beautifully. I can say the TV knows when something is plugged into an HDMI port because it will show up on the source list. Even when I move the device from HDMI1 to 2, 3, or 4 it'll move in the list, but never produces video or sound.
Would the main board be suspect in this case? or something else? Again component works great, but HDMI does not. I have not tested the VGA input yet. I can post pictures of boards and such tonight if necessary.
