samsun un46d6000 led tv with blurred double image
  • jas_stang
    • Feb 2013
    • 10
    Re: samsun un46d6000 led tv with blurred double image
    i looked at the tv briefly today, i didnt have my meter with me to test voltages on the power supply. i did find that with one ribbon cable unhooked half the screen works great, when you plug it in it returns to a double image. i found that if you plug the ribbon cable in but dont close the lock and apply pressure in the right spot, i get the tv to have a clean and clear picture like normal. i am now thinking it is a bad ribbon cable from the tcon board to the panel. this number is printed on it: YK1330G2 2269. i am going to research a replacement. hope this fixes it!!
      You could ask any sellers who have broken up this TV if they have kept those cables.
      • jas_stang
        • Feb 2013
        • 10
        i tried 4 different cables and also replaced power supply with a known good one. still having same issues. I am able to release lock on panel ribbon cable and hold in a certain spot to attain a good picture with minimal display issues but do see very small lines. any other advice? bad panel???
        • nate101
          • Oct 2013
          • SA
          I have exactly the same issue.What was the final outcome?
          • johnboy1313
            • Nov 2012
            • 1959
            Seems like a bad panel. Everything in the TV was replaced and the problem persisted. There's only the panel left.
            • davedavid85
              • Jul 2014
              • 3
              • United States of America
              #26
              I had the same problem with my Samsung 40" LED tv. I was able to fix it for no money, all on my own. It took a little bit to get the picture back but it was a very easy fix. Watch this video on YouTube. I hope this helps.
              https://www.youtube.com/watch?v=j7vl7-vZEL8
              • Deblackmon3
                • Aug 2014
                • 3
                Hi everyone! I have one of these on my desk right now, and I've been doing the regular troubleshooting for blurred images (reseating ribbon cables, panel tabs etc, checking voltages on the t-con and main boards). I cleaned all of the cable connections to remove any static buildup, but that did not work. Searched and found this thread with a similar problem.
                Here's an image of the problem- double lines everywhere, and the picture keeps jumping.
                • davedavid85
                  • Jul 2014
                  • 3
                  #28
                  I had a double image problem with my Samsung and was able to fix it for $0.00 all by myself. Check out this video on YouTube.
                  by David Koenig
                  • howardc64
                    TCL 49S405 double image
                    by howardc64
                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                    06-23-2025, 03:20 PM
                  • Cornito
                    Samsung UE55RU8000 reboot and then double image after heating up
                    by Cornito
                    Hello team,
                    I'm back with another tv and another problem.
                    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                    First, reboot issue, I use tape Method to find out the right side that cases the issue.
                    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                    Then double image reduce in height and move to the top.
                    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                    When I...
                    03-31-2024, 01:37 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                  • piershs
                    Toshiba plasma 50WP16 wierd double image fault
                    by piershs
                    My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                    Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                    • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                    • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                    08-01-2020, 01:07 PM
                    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-06-2024, 10:56 AM
