Sanyo DP50747-00 Plasma No Video Good Audio
  • kevinm34232
    • May 2012
    • 1884
    Sanyo DP50747 Chassis 00
    Panel: Samsung S50HW-YD02
    Symptoms: TV powers up and stays powered up, have audio, but no video. Tried to look for a 'glow' but best I can tell there is nothing. It's pretty bright in here so I rolled up some black construction paper and made a tube out of it but saw no change in lighting.
    I did see one or two random lights kinda shoot around the screen for a second on power up.
    I have not repaired a plasma yet and am actually surprised and pleased that this one powers on and stays on with audio. I had a Sanyo 50747-04 before that shut down with a main board PFC and never figured it out.
    This would be my first real attempt at a plasma repair so I'm looking forward to learning more about it...
    I do not have a scope BTW... Thanks!
    Re: Sanyo DP50747-00 Plasma No Video Good Audio
    First step is to measure Vs and Va on the PSU, and compare them to the panel sticker ratings.
    • kevinm34232
      • May 2012
      • 1884
      Sticker:
      VA=63
      VS=205
      Reading off PS:
      VA=63.2
      VS=206
      VG?= 15.05
      Going to eat will be back soon.. Thanks!!
        Good voltages, close enough. There are fuses on the Y-main and X-main. Check those for continuity, and replace them if they have failed. If the TV then fails to power up, or the fuse has failed, you likely have the common 88N30 FET failure; one buffer IC may need replacing too.
        • kevinm34232
          • May 2012
          • 1884
          Both fuses are good. Where are the FET's to check?
            If the fuses are good, it's not the FETs.
            Suspect the control board.
            The LED on it should blink.
            Does it?
            • kevinm34232
              • May 2012
              • 1884
              Was just poking around aimlessly and discovered...
              F5700 is open..
              R5009 reads about 40k ohms..
              • kevinm34232
                • May 2012
                • 1884
                Yes LED blinks on control board
                  It looks like C5708 is bulging to me.
                  • kevinm34232
                    • May 2012
                    • 1884
                    You're right it's under the heat sink but it is bulging (c5709). F5700 has 1A LF (Littlefuse) on it, and R5009 has 4 bands, brown, black, yellow and gold and resisitor is cyan in color. Can you give me possible replacements for the fuse and resistor??
                    Is it likely to just be those components? Did not find any replacement Y Mains with a quick search.
                      I've done the 42" of this chassis (Samsung branded though) and had the same cap bulging in a different area, it causes the Y-Main to stop working, and give you no image at all. 100uF 50V, I guess?
                      Replace the fuse with any 1A through hole picofuse; what rail does it connect to? Probably for the 15V rail.
                      • tocold4u2
                        • Dec 2012
                        • 284
                        • usa
                        10x10k=100k5% brown=1 blk=0 x yellow =10k gold= 5% i think this is right but ask others to make sure
                          Yeah I think it's 100k too. 40k is in circuit. It's probably fine.
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            i got a pk of resistors and it shows on the back how to figure them,,,,,,,which is helpful!!
                            • kevinm34232
                              • May 2012
                              • 1884
                              Without pulling it out it looks like its a 25V 680uF cap.
                                The one I replaced was 100uF 50V, but they may have changed the design.
                                Replace the fuse.
                                Replace that capacitor.
                                See if TV works again.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  http://www.diyalarmforum.com/4-band-resistor-calc/
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Replaced fuse F5700 (Pico Fast 1A 125V) and capacitor C5709 (680uF 25V), TV working now, thanks Tom!!
                                      So, in the end, it wasn't too difficult was it?
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Not this one at least, nothing compared to others I've seen here. I still have 1 more big Samsung in the car tho!
