Sceptre X460BV-F120 2 seconds to power off.
    Re: Sceptre X460BV-F120 2 seconds to power off.
    Measure the voltage across the suspect capacitor. We expect from 11.5V~25V. It would be a good idea to solder, or wrap around leads on the components, and measure using the flying leads.
    • johnboy1313
      • Nov 2012
      • 1959
      Measured across the cap pointed to in post #38, I get a steady 8.1V until the "click", as I've been calling it, and the voltage briefly jumps to ~9.6V. With the + probe on the + leg of the that cap, and the - probe on the - leg of the big cap, the voltage holds steady at 8.1V but sometimes jumps to ~9.5V and sometimes drops to ~7.5V at the "click".
        So it's not reaching the right voltage, as that's right near the under-voltage cut-off for that IC.
        It is possible the controller IC is faulty (it has become leaky on the Vcc pin.)
        Can you measure the resistance that appears across that capacitor?
        If it's not that it could be something to do with the network which charges that cap once it is running. There should be two diodes and a small ceramic capacitor for this circuit.
        • johnboy1313
          • Nov 2012
          • 1959
          Should I measure the resistance with the cap in circuit or out?
            In circuit, we want to measure the Vcc resistance.
            • johnboy1313
              • Nov 2012
              • 1959
              With the DMM on 2000k and the + on the + leg and the - on the - leg, the resistance slowly rises until overload. With the probes swapped the resistance rises to ~1650k and stops.
                So it's not leaky.
                I see the chip is under $5 on eBay. I'd suggest you swap it, if it's not that, we need to look elsewhere -- I'm not sure how to rule it out, other than swapping it. But first, check those other components I mentioned.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I think I'm just going to replace the whole PSU. There's one online for $45 shipped. Ideally, I'd like to fix this one but I'm beginning to think I could chase it forever and I'll never figure the problem out. I'm not quite ready to throw in the towel but until I know for sure what is causing this issue, I don't want to spend a dime on this psu.
                    Hmm, for a 46", a $45 investment isn't too bad. This is a 120Hz display, too, though I've never liked that feature.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      New PSU came in today and acts exactly like the old PSU. With inverters connected, backlight strobes like a dance party when the PSU is forced on. With the inverters disconnected, the voltage across the big cap is all over the place. I'm not sure where to go from here.
                        Well that makes no sense at all. The problem is almost certainly with the PSU. Was the part guaranteed functional?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Yes. My suspicions are starting to point elsewhere, I just don't know where.
                            The only way you're going to see a dip in PFC voltage is a problem with the power supply or perhaps a signal from the main board to PSU is not correct.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Originally posted by johnboy1313
                              I have the set plugged into a surge protector. With the probes of my DMM on the leads of the primary cap, when I turn the surge protector on, the voltage jumps to 394V immediately and slowly drops to 169V. The whine from the transformer gets higher at the same rate as the voltage drops on the primary cap. When the set is powered on, the voltage on the cap jumps to 394V and stays there until the set is powered off.
                              This is from post #4, the new PSU acts the same way. It seems like the PFC circuit is working correctly with everything connected.
                                You should check the ripple on the scope outputs and see if it is the same as before.
                                Also, just checking... you definitely installed the new PSU? Didn't accidentally install the old one? I've done that before!
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  No, it's the new one for sure.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    I'm probably not going to have the time to get back to this one tonight.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      https://www.youtube.com/watch?v=3NKOBHoTocA
                                      The seller of the PSU just responded that this PSU was confirmed to be working when pulled. So, I guess the video is a moot point now. I am going to send this back and get the main from the same guy. I'm not real keen on buying boards on a whim so if it does turn out to be the main that is bad, at the least the seller gets something outta me.
                                        I do not trust sellers who say that, they rarely ever test the boards they pull.
                                        Who knows perhaps someone's TV was doing this and in frustration they hit it and broke the screen. Seller picks it up strips it for parts & lists them.
                                        You have ripple on PSU outputs. Is this present with load such as car brake light bulb and no main board/inverter etc.? There is only one way the ripple can happen. The PSU causes it or excessive load causes it.
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          With 12V disconnected from the main but 16V still connected, this happens.
                                          https://www.youtube.com/watch?v=gEnabqLCWys
                                          • twonk9098
                                            Lenovo Legion 5 high fan spin turns off after 34 seconds
                                            by twonk9098
                                            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                            I have tried a few new bios but exactly...
                                            07-14-2024, 11:19 AM
                                          • liquidzorch
                                            Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                            by liquidzorch
                                            Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                            10-18-2024, 05:19 PM
                                          • Rick_1234
                                            by Rick_1234
                                            Good evening, gentlemen.
                                            Things I tried
                                            06-22-2024, 04:44 PM
                                          • PowellSkier
                                            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                            by PowellSkier
                                            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                            06-17-2024, 11:43 AM
                                          • AlexVG
                                            Macbook A1466 820-00165 resets every 10 seconds
                                            by AlexVG
                                            It have had a problem with U7100 and short circuit in Q7130.
                                            I replaced them.
                                            It starts now and waiting 20 seconds and then starts to reset PM_SLP_S4_L every 10 seconds.
                                            Almost all voltages rising
                                            except U3090 and U3210 (LED) - not receives enable signal.
                                            U4500 is trying to rise - receives enable only 2-3 seconds
                                            Here is my measuring of important signals.
                                            What else could be the problem?
                                            I need to help.
                                            Thank you an advance....
                                            11-09-2023, 07:19 AM
