Samsung pn58b860 Clicking
    Re: Samsung pn58b860 Clicking
    It's the white one right next to it.
    • awyatt2
      • Feb 2012
      • 407
      • america
      the round reddish orange is a zener diode, the fuse is the white rectangle next to it.
      • ptheman12345
        • Dec 2012
        • 42
        • usa
        ohhh, okay. Just measured the white one and i'm getting a reading of around 5.2V
          Ok, so it uses 5.2V, that is still OK, 15V for the sustain board may come in on the main connector instead.
            Regarding the clicking, does it just click two or three times, or does it continue to click when plugged in?
            Have you owned the TV since new and if so did you turn off the "Samsung melody" which makes sound when the TV is turned on? If not, do you hear the start up tone?
            • ptheman12345
              • Dec 2012
              • 42
              • usa
              #26
              When I initially plug it in, the red standby led turns on. Once I press the power button on the tv, it goes into a cycle where it tries to turn on (clicks), but then turns off (clicks again). The cycle goes on forever unless I unplug it from the wall. As for the melody, the tv doesnt stay on long for it to sound.
                Hmm, I did not realise this from the original post -- may have missed it. Does Vs drop out while it clicks? It could be the main board if it is doing that.
                • ptheman12345
                  • Dec 2012
                  • 42
                  • usa
                  #28
                  The 2 green LED on the control, 1 on the Y main, and 1 on the X main all blink when it initially tries to start up if that matters.
                  • ptheman12345
                    • Dec 2012
                    • 42
                    • usa
                    #29
                    Does it matter where I measure the Vs at? I measured it where the Y main connects to the power supply. It would rise to around 202V when it first clicks on, but then drop when it clicks off
                      It doesn't matter on which board, they are both the same.
                      Does it ramp down slowly or very suddenly drop?
                      • ptheman12345
                        • Dec 2012
                        • 42
                        • usa
                        #31
                        It rises to 202V on the first click then drops to around 160V 4 seconds after the second click off
                          If a board were shorted I would expect a drop to 0V but since that's not the case, the fault is probably elsewhere.
                          On the power supply there should be a legend near the connector going to the main board. There should be a pin marked PSON. Do you see this?
                          • ptheman12345
                            • Dec 2012
                            • 42
                            • usa
                            #33
                            yes i see it
                              Can you test the voltage on the pin. Does it change when it clicks off.
                              • ptheman12345
                                • Dec 2012
                                • 42
                                • usa
                                #35
                                just tested it. The ps on goes to 3.12V when it clicks on, but then goes to 0V when it clicks off
                                • ptheman12345
                                  • Dec 2012
                                  • 42
                                  • usa
                                  #36
                                  the ps on is on the second underlining row correct? i had to use a thin metal wire and poke it in to get a reading
                                    Since it is going off when the TV goes off, this makes me suspect the main board instead. It's possible the control board doesn't have enough time to start up. Can you get hold of a 100~470 ohm resistor? It can be used to force on PSON, and then the test patterns can be enabled. This should help locate the fault...
                                    • ptheman12345
                                      • Dec 2012
                                      • 42
                                      • usa
                                      #38
                                      Scratch what I said previously. Those readings are wrong. The correct ps on reading is 3.21V when the tv set clicks off and 0.2V when it clicks on
                                        OK, but 0.2V is still off for the PSU.
                                        • ptheman12345
                                          • Dec 2012
                                          • 42
                                          • usa
                                          #40
                                          do you suspect the power supply is causing it to fault?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
