please help
  • allaoua barika
    • Dec 2012
    • 18
    • algeria
    please help
    J'ai un problème a' mon ecran samsung S22A100N (bn41-01726b) la composant Dans l'image suivante Je ne savais pas ce que S'il vous plaît je veux son nom et le numéro de
    http://s13.postimage.org/4g4dubxiv/K...Oy_D_60_58.jpg
  • mariushm
    • May 2011
    • 3799
    Re: please help
    Can you stop this? It's really annoying.
    You already asked in a thread, actually in TWO threads, wait for answers on those threads to your problem.
    And for the 2nd or 2rd time, "PLEASE HELP" is not a proper name for a thread.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: please help
      Well dont look - you can block his threads so you dont see.
      Problem I think is he only speaks fluently in arabic.
      I will handle it.
      • bohaboha
        • Nov 2012
        • 1044
        • sweden
        Re: please help
        Salam ecoute mon Ami il faut cesser de les harceler avec tes appel en secours
        des qu ils ont la possibilitee ils t aideront mais aussi tu dois suivre un minimum de
        souplesse et faire ou leurs presenter ce qu ils te demande.
        c est la troisieme fois que tu le fait au lieu de lire ce qu Selldoor t as dejas
        demander de faire et puis patience mon ami
        • allaoua barika
          • Dec 2012
          • 18
          • algeria
          Re: please help
          my skype is allaoua430 call me please
          • allaoua barika
            • Dec 2012
            • 18
            • algeria
            Re: please help
            Really I'm sorry for the inconvenience, but if I find a solution for you repeated the request
            • FaissalDZ
              samsung SA100 S22A100N dump
              by FaissalDZ
              Hi everyone!
              I need dump for Samsung monitor SA100.
              Model: S22A100N
              Thank you in advance....
              11-26-2021, 04:10 AM
            • baas62
              Burnt resistor MSI B550 Tomahawk Max
              by baas62
              Hello everyone
              I have an MSI B550 Tomahawk Max Wi-Fi motherboard that has burned out components. See photos below.
              I tested the rest of the board, and everything seems to be working properly and stable. I tested it in-game with a 1650 GPU, just in case, and in Cinebench.
              I didn't install an NVME SSD on the first port but only a sata 6gb classic 2.5 inch ssd
              I checked the warranty on the MSI website, and the board is still under warranty until May 2026, but unfortunately I don't have the receipt to request an RMA.
              Is there anyone...
              08-02-2025, 01:38 AM
            • telenaze
              Samsung UE40C6000 panne TCON V460H1-CH7 en C/C
              by telenaze
              Bonjour,
              Je possède un Samsung UE40C6000 dont la carte TCON V460H1-CH7 est en C/C.
              Le composant C-DF1 est coupé, j'ai donc réalisé une commande de fusible SMD 63V 2A.
              j'ai trouvé le composant qui faisait le C/C, la ref sur la carte est C_D1C18.
              sans le schéma, je ne sais pas quoi mettre à la place de composant HS, pourriez vous me venir en aide ?
              Merci,
              [/URL][/IMG]
              [/URL][/IMG]...
              01-15-2022, 10:24 AM
            • brass19@
              UE58J5000 PSU ICP8101
              by brass19@
              bonjour, je recherche un composant est son datasheet le problème il est pas lisible j ai pu relevé S3051 541 ICP801 carte alimentation tv UE58J5000 merci de votre aide(impossible de trouver un schéma)
              [MOD EDIT] Translated text:
              hello, I am looking for a component is its datasheet the problem it is not readable I was able to read S3051 541 ICP801 tv power supply card UE58J5000 thank you for your help (impossible to find a diagram)
              12-22-2023, 04:06 AM
            • blues_spirit
              practical courses for troubleshooting pc motherboards
              by blues_spirit
              Hello from France,
              mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
              Do you think this is feasible for me? I...
              12-18-2022, 12:56 PM
