Samsung PN64D7000 Keeps Power Cycling Never Stays On
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Samsung PN64D7000 Keeps Power Cycling Never Stays On
    At this time, these main boards are discontinued and no longer available. There are some third party sellers available online which have them listed for around $200 and up, but those are going to be used boards.
    Alternatively you can send in the main board to get serviced and fixed for around $80-$90. Your Nand chip which contains the software for the TV has failed and needs to be replaced. This is something that would be considered generally to be advanced sodlering since there are 48 pins to solder. If you are good with an iron and have experience, I suggest you go for it. You can buy the Nand preprogrammed for $35 from eBay.
    If you do choose to send it in for repair, let me know, we service that board often and offer a 1 year warranty on our repairs.
      09-07-2024, 05:50 AM
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
